linux_newbie
multiple MSI interrupts from PLBv46_PCIE bridge
I need to have more than one MSI interrupts from the PLBv46_PCIe bridge. In order to implement this feature apart from the MSI_request signal I need to export cfg_interrupt_di[7:0] to top level interface of the PLBv46_PCIe bridge. But I do not know if multi-vector MSI option is enabled in the PCIe endpoint netlist which is instantiated in the PLBv46_PCIe bridge. Can I get a clear answer before I proceed to do the change? Or is there any software solution?
Cheers
deepeshm
Currently only one MSI is supported. You might be able to tweak the provided source but this wouldn't be a supported flow.
kre8si
i need obnly one MSI Interrupt to send an Interrupt to the HOST PC.
But i don't understand how i can do this.
Can you give me short Instruktions what i have to do?
I have a ML507 with the PLBv46_PCIE bridge.
