lokeshreddy
pci connector
hi,
   I am to communicate virtex7 board to texas board.Is it possible to communicate through pci express.any connector is required to make communication through pci
umamahe
As per PCI express standard we need to use standard connector & pinout.
PCI Express connector pinout  is available in ×1, ×4, ×8 and ×16 variants.
Please refer https://www.pcisig.com/developers/main/training_materials/get_document?doc_id=6d37ec2f8543fc1f9d8ace6264d08b469f57e5f1 for more details. Also refer https://www.pcisig.com/specifications/pciexpress/ to know more about different versions of PCIE standards
FYI: Xilinx provides high performance and low power integrated hard block PCIe solution in Xilinx All Programmable devices at no extra cost. Xilinx also provides soft blocks, boards, connectivity kits, reference designs, drivers and tools to further enhance user experience in implementing PCIe based designs.Please refer the below link documents about Xilinx PCIE related information
http://www.xilinx.com/products/technology/pci-express.html
http://www.xilinx.com/products/intellectual-property/7_series_pci_express_block.html#overview
http://www.xilinx.com/products/intellectual-property/7_series_pci_express_block.html#documentation
kotir
Does the texas board contains any PCIe slot ?
Usually users have PCIe cards like VC707,VC709 build with PCIe connector to insert it into slot of any mother board.
If your Texas board contains similar slot , then you can use any Evalucation board lile VC707/VC709 to use PCIe based design.
KR
vijayak
Moving to correct board.
Thanks,Vijay
