Observer babu_image@
pcie RC ---waiting for the signal
Hi Guys,
 In my Project, I am using PCIE example(IP) design(we are directly getting from vivado .Ultra Scale Devices Gen3 Integrated Block for PCI Express v4.4 ) . In stead of their design ,I am  using my design . the problem is--need to send the data  from pcie_core to RC model .I have awaddr ,awvalid ,wvalid &wdata these four I need to send to RC model.
 In AXI we are sending awvalid from master to slave ,at that slave will tell I am ready to accept your address (i.e awready) ,like that what is the signal we have from RC Model
Thanks in advance !!!!!!!
Re: pcie RC ---waiting for the signal
I'm not sure if I understand your question correctly. Do you expect a reply from RP on AXI bus after you send a request from EP ( FPGA ) to RP?
If your request is Memory Read ( Non-Posted), RP returns a completion and PCIe core as EP puts the read data on AXI bus. However, If your request is Memory Write ( Posted), RP does not reply using a packet to EP and the user logic does not see a reply from RP. Handshaking between RP and EP is done at Data Link Layer.
thanks for your reply kurihara . actually what I am doing is , I am forcing the values into PCIE core.so I am unable to see those values into EP.
In Xilinx example ,they gave sample_tests.v file , in that file totally three test cases are there .so I am using pio_write_back _test case for single read and write. now I am forcing the values at pcie core, I am unable to understand , where i need to force the values in the test case. can you please help me out.
If you use Xilinx example tests:  "pio_writeReadBack_test0" instead of your design and you also want to change the write data, changed the following values depending on the EP's BAR setting ( 32 or 64 Space)
// Event : Memory Write 32 bit TLP
board.RP.tx_usrapp.DATA_STORE[0] = 8'h04;
board.RP.tx_usrapp.DATA_STORE[1] = 8'h03;
board.RP.tx_usrapp.DATA_STORE[2] = 8'h02;
board.RP.tx_usrapp.DATA_STORE[3] = 8'h01;
board.RP.tx_usrapp.DATA_STORE[4] = 8'h14;
board.RP.tx_usrapp.DATA_STORE[5] = 8'h13;
board.RP.tx_usrapp.DATA_STORE[6] = 8'h12;
board.RP.tx_usrapp.DATA_STORE[7] = 8'h11;
or
// Event : Memory Write 64 bit TLP
board.RP.tx_usrapp.DATA_STORE[0] = 8'h64;
board.RP.tx_usrapp.DATA_STORE[1] = 8'h63;
board.RP.tx_usrapp.DATA_STORE[2] = 8'h62;
board.RP.tx_usrapp.DATA_STORE[3] = 8'h61;
board.RP.tx_usrapp.DATA_STORE[4] = 8'h74;
board.RP.tx_usrapp.DATA_STORE[5] = 8'h73;
board.RP.tx_usrapp.DATA_STORE[6] = 8'h72;
board.RP.tx_usrapp.DATA_STORE[7] = 8'h71;
thanks kurihara for continuous replies
I need to force the values on pcie core.
  pcie core having master and slave. I am forcing the values at master side.
  force  m_axis_awaddr = 32'habcd;
  force  m_axis_awvalid = 1;
  force m_axis_wvalid =1;
  force m_axis_wdata = 32'h abcd_abcd;
the above traffic i need to see in the root complex signals.
where I need to put the above code in the test case file (sample_test.v file).
To send the packet to RP, you will need to drive S_AXI port of the Bridge.
Check xilinx_axi_pcie4_ep.v file. You can find access to both m_axi_* and s_axi_* ports .
