r5h1n
pcie endpoint block plus v1_14
Hello .
when i generate the core of pcie "endpoint block plus v1_14"  it gives following warning messages:
WARNING:sim:215 - This core does not support ASY symbol generation.
WARNING:sim:93 - NGC output will not be generated for this core.
I got instantaition tempalate, but when i synthesise the design in ISE 12.2 it give two error messages;
ERROR:HDLCompilers:27 - "ipcore_dir/ppp/example_design/dual_core/xilinx_pci_exp_secondary_ep.v" line 57 Illegal redeclaration of 'xilinx_pci_exp_secondary_ep'
ERROR:HDLCompilers:27 - "ipcore_dir/ppp/example_design/pci_exp_1_lane_64b_ep.v" line 56 Illegal redeclaration of 'ppp'
I just simply instantiated the design and define the input and output and then synthesised it and got these errors .
completely stuck in the begining...
regards,
r5h1n
luisb
Did you add all of the RTL in the "example_design" and "source" directories?  Or did you just add the XCO into the project?
I would recommend to add all of the files that are listed in the .xst file in the "implement" directory.  I wouldn't include any more than the files that are listed in that file.  This should allow you to implement the example design within ISE.
luisb
r5h1n
I just added xco into my project. now i added the example design.
thanks it synthesises successfully.
If I want to add my own logic to tx and rx my own required data then where should add it ??
regards,
r5h1n
r5h1n
regards,
r5h1n
