rasith
pcie lane
    In pcie x8 lane,
    lane 0 and lane 7 was not working what is behavior of PCIE root complax ?
rasith
kotir
If lane zero is not working , then link will not be up.
If lane7 alone not working , then the link will train down to x4 instead of x8(targetted)
KR
rasith
  In x8 PCIE lane without lane reversal,
1: lane 0,lane 2,lane 7 is not working then root complex train the link as x4 used
i.e., lane 1,3,4,5 act as lane0,1,2,3 .Is it correct?
2: lane 3 is not working then root complex train the link as x4 used
i.e.,lane 4,5,6,7 act as lane 0,1,2,3. Is it correct?
3: lane 3 is not working then root complex train the link as x2 used
i.e.,lane 0,1 act as lane 0,1, and all other lanes are inactive. Is it correct?
rasith
kotir
Hi ,
It does not work that way.
Have a look at the Base specification section 4.2.2 (Framing and Application of Symbols to Lanes).
It says as below.
For Links wider than x1, the STP Symbol (representing the start of a TLP) must be placed in
Lane 0 when starting Transmission of a TLP from a Logical Idle Link condition.
For Links wider than x1, the SDP Symbol (representing the start of a DLLP) must be placed in
Lane 0 when starting Transmission of a DLLP from a Logical Idle Link condition.
If lane zero does not work , the is no link up.
Koti Reddy
