pcie on xc6vlx130t not translating
I am currently trying to implement a Xillybus PCIe core on a Virtex-6 xc6vlx130t
As per the instructions on the Xillybus webpage I copied over the constraints from the example design and modified the LOC constraints according to my manufacturer's reference. I should add, that I have gone through this procedure a few times for Spartan-6 devices and it worked every time.
However this time I end up having problems translating the design. I receive the  following error:
ERROR:NgdBuild:604 - logical block
   'xillybus_ins/pcie/pcie_2_0_i/pcie_gt_i/gtx_v6_i/GTXD[0].GTX_DRP_CHANALIGN_FI
   X_3752' with type 'GTX_DRP_CHANALIGN_FIX_3752_V6' could not be resolved. A
   pin name misspelling can cause this, a missing edif or ngc file, case
   mismatch between the block name and the edif or ngc file name, or the
   misspelling of a type name. Symbol 'GTX_DRP_CHANALIGN_FIX_3752_V6' is not
   supported in target 'virtex6'.
   'xillybus_ins/pcie/pcie_2_0_i/pcie_gt_i/gtx_v6_i/GTXD[1].GTX_DRP_CHANALIGN_FI
   'xillybus_ins/pcie/pcie_2_0_i/pcie_gt_i/gtx_v6_i/GTXD[2].GTX_DRP_CHANALIGN_FI
   'xillybus_ins/pcie/pcie_2_0_i/pcie_gt_i/gtx_v6_i/GTXD[3].GTX_DRP_CHANALIGN_FI
As you can see the problem is actually inside the Xilinx PCIe core itself, and has nothing to do with the Xillybus code. Regenerating the core to ensure it is for the current architecture had no effect.
Upgrading the core to the newest version (the Xillybus pcie core is v1.7) is not an option, since the 2.5 version uses an AXI interface. Anyway the 1.7 version is not deprecated, so should work.
I then thought that I might have a problem with copying the XCO core from the example design and generated the core from scratch using coregen, simply setting the settings identical to the ones in the Xillybus example. Again to no effect.
I presume there is a problem inside the PCIe core connected to the part number I use, since the ML605 version worked for me in the past.
Has someone encountered this problem before and solved it?
Thanks in advance for any help.
Best regards
Hi there,
So the problem stemmed from the XCO file not having the correct file list it appears.
Instead of adding the XCO file to the project, the solution was to add all generated VHDL files manually.
Hopefully this helps someone in the future.
Hi there,
