pdb and exe scripts for dma testing
I have programmed the KCU 1500 board using Vivado 2018.1. My platform is Windows 10 and I have used the Xilinx xdma driver for Windows. Along with the drivers there are some tests that you can perform like moving data from host to card and vice versa.
I have successfully completed all the tests.
Now I want to test my custom logic and interface. So in order to do this, I want to understand the scripts that transfer data between FPGA and the host. In dma folder, the tests are in pdb and exe format. Is there a way I can get the source files for those? I really need to understand how to write a custom script for the dma transfer!
Thank you.
Hi @vivek,
You might consider taking a look at the Linux sources.  Otherwise, I would contact your Xilinx FAE or Sales team for access to the Windows Driver Lounge where source is available.
Hi @vivek,
@bethe - Thank you.
I do have the Linux source files. I will contact the Xilinx FAE.
Thank you.
