kynthia9
simulation failed on artix 7 pcie example design.
I am running an example design of artix 7 pcie core with pipe interface enabled (core with external sharing clock).
vivado version 2016.2
console log showed as following:
INFO: [Simtcl 6-17] Simulation restarted
run all
[ 0] board.RP.rport.genblk1.model_ap2_tst_pcie_top_i.model_ap2_tst_pcie_7x_i.model_ap2_tst_pcie_bram_top.model_ap2_tst_pcie_brams_tx NUM_BRAMS 4 DOB_REG 1 WIDTH 18 RAM_WRITE_LATENCY 0 RAM_RADDR_LATENCY 0 RAM_RDATA_LATENCY 2
[ 0] board.RP.rport.genblk1.model_ap2_tst_pcie_top_i.model_ap2_tst_pcie_7x_i.model_ap2_tst_pcie_bram_top.model_ap2_tst_pcie_brams_rx NUM_BRAMS 4 DOB_REG 1 WIDTH 18 RAM_WRITE_LATENCY 0 RAM_RADDR_LATENCY 0 RAM_RDATA_LATENCY 2
[ 0] board.RP.rport.genblk1.model_ap2_tst_pcie_top_i.model_ap2_tst_pcie_7x_i.model_ap2_tst_pcie_bram_top ROWS_TX 1 COLS_TX 4
[ 0] board.RP.rport.genblk1.model_ap2_tst_pcie_top_i.model_ap2_tst_pcie_7x_i.model_ap2_tst_pcie_bram_top ROWS_RX 1 COLS_RX 4
Running default test {pio_writeReadBack_test0}......
[ 0] : System Reset Asserted...
[ 2500000000] : Simulation timeout. TEST FAILED
run: Time (s): cpu = 00:09:58 ; elapsed = 04:17:52 . Memory (MB): peak = 6166.273 ; gain = 42.035 ; free physical = 136310 ; free virtual = 250342
could anyone give some advice?
venkata
Can you share the .xci of the IP? which simulator are you using?
kynthia9
I am using vivado 2016.2 embedded simulator
I cannot upload files since keep receiving error like:The attachment's axi_pcie_1.xci content type (application/octet-stream) does not match its file extension and has been removed
here paste xci file in text
<?xml version="1.0" encoding="UTF-8"?>
<spirit:design xmlns:xilinx="http://www.xilinx.com" xmlns:spirit="http://www.spiritconsortium.org/XMLSchema/SPIRIT/1685-2009" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<spirit:vendor>xilinx.com</spirit:vendor>
<spirit:library>xci</spirit:library>
<spirit:name>unknown</spirit:name>
<spirit:version>1.0</spirit:version>
<spirit:componentInstances>
<spirit:componentInstance>
<spirit:instanceName>axi_pcie_1</spirit:instanceName>
<spirit:componentRef spirit:vendor="xilinx.com" spirit:library="ip" spirit:name="axi_pcie" spirit:version="2.8"/>
<spirit:configurableElementValues>
<spirit:configurableElementValue spirit:referenceId="ADDRBLOCK_RANGE.S_AXI.BAR0">4G</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="ADDRBLOCK_RANGE.S_AXI.BAR1">4G</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="ADDRBLOCK_RANGE.S_AXI.BAR2">4G</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="ADDRBLOCK_RANGE.S_AXI.BAR3">4G</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="ADDRBLOCK_RANGE.S_AXI.BAR4">4G</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="ADDRBLOCK_RANGE.S_AXI.BAR5">4G</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="ADDRBLOCK_RANGE.S_AXI_CTL.CTL0">256M</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.AXI_ACLK_LOOPBACK">FALSE</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_AXIBAR2PCIEBAR_0">0x00000000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_AXIBAR2PCIEBAR_1">0x00000000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_AXIBAR2PCIEBAR_2">0x00000000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_AXIBAR2PCIEBAR_3">0x00000000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_AXIBAR2PCIEBAR_4">0x00000000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_AXIBAR2PCIEBAR_5">0x00000000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_AXIBAR_0">0x00000000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_AXIBAR_1">0xFFFFFFFF</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_AXIBAR_2">0xFFFFFFFF</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_AXIBAR_3">0xFFFFFFFF</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_AXIBAR_4">0xFFFFFFFF</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_AXIBAR_5">0xFFFFFFFF</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_AXIBAR_AS_0">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_AXIBAR_AS_1">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_AXIBAR_AS_2">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_AXIBAR_AS_3">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_AXIBAR_AS_4">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_AXIBAR_AS_5">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_AXIBAR_HIGHADDR_0">0xFFFFFFFF</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_AXIBAR_HIGHADDR_1">0x00000000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_AXIBAR_HIGHADDR_2">0x00000000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_AXIBAR_HIGHADDR_3">0x00000000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_AXIBAR_HIGHADDR_4">0x00000000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_AXIBAR_HIGHADDR_5">0x00000000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_AXIBAR_NUM">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_BASEADDR">0x00000000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_CLASS_CODE">0x0B4000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_COMP_TIMEOUT">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_DEVICE">xc7a200t</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_DEVICE_ID">0x1030</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_FAMILY">artix7</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_HIGHADDR">0x00FFFFFF</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_INCLUDE_BAROFFSET_REG">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_INCLUDE_RC">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_INSTANCE">axi_pcie_1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_INTERRUPT_PIN">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_MAX_LINK_SPEED">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_MSI_DECODE_ENABLE">TRUE</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_M_AXI_ADDR_WIDTH">32</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_M_AXI_DATA_WIDTH">128</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_NO_OF_LANES">4</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_NUM_MSI_REQ">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_PCIEBAR2AXIBAR_0">0x00000000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_PCIEBAR2AXIBAR_0_SEC">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_PCIEBAR2AXIBAR_1">0x40000000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_PCIEBAR2AXIBAR_1_SEC">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_PCIEBAR2AXIBAR_2">0x80000000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_PCIEBAR2AXIBAR_2_SEC">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_PCIEBAR_AS">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_PCIEBAR_LEN_0">26</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_PCIEBAR_LEN_1">26</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_PCIEBAR_LEN_2">31</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_PCIEBAR_NUM">3</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_PCIE_BLK_LOCN">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_PCIE_CAP_SLOT_IMPLEMENTED">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_PCIE_USE_MODE">1.0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_REF_CLK_FREQ">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_REV_ID">0x01</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_RP_BAR_HIDE">FALSE</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_SLOT_CLOCK_CONFIG">TRUE</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_SPEED">-2</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_SUBSYSTEM_ID">0x0000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_SUBSYSTEM_VENDOR_ID">0x1AEE</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_S_AXI_ADDR_WIDTH">32</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_S_AXI_DATA_WIDTH">128</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_S_AXI_ID_WIDTH">4</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_S_AXI_SUPPORTS_NARROW_BURST">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_VENDOR_ID">0x1AEE</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_XLNX_REF_BOARD">NONE</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.EXT_CH_GT_DRP">FALSE</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.EXT_PIPE_INTERFACE">TRUE</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.NO_SLV_ERR">FALSE</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.PCIE_EXT_CLK">TRUE</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.PCIE_EXT_GT_COMMON">FALSE</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.SHARED_LOGIC_IN_CORE">FALSE</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.TRANSCEIVER_CTRL_STATUS_PORTS">FALSE</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.AXIBAR2PCIEBAR_0">0x00000000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.AXIBAR2PCIEBAR_1">0x00000000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.AXIBAR2PCIEBAR_2">0x00000000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.AXIBAR2PCIEBAR_3">0x00000000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.AXIBAR2PCIEBAR_4">0x00000000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.AXIBAR2PCIEBAR_5">0x00000000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.AXIBAR_0">0x00000000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.AXIBAR_1">0xFFFFFFFF</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.AXIBAR_2">0xFFFFFFFF</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.AXIBAR_3">0xFFFFFFFF</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.AXIBAR_4">0xFFFFFFFF</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.AXIBAR_5">0xFFFFFFFF</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.AXIBAR_AS_0">true</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.AXIBAR_AS_1">false</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.AXIBAR_AS_2">false</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.AXIBAR_AS_3">false</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.AXIBAR_AS_4">false</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.AXIBAR_AS_5">false</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.AXIBAR_HIGHADDR_0">0xFFFFFFFF</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.AXIBAR_HIGHADDR_1">0x00000000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.AXIBAR_HIGHADDR_2">0x00000000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.AXIBAR_HIGHADDR_3">0x00000000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.AXIBAR_HIGHADDR_4">0x00000000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.AXIBAR_HIGHADDR_5">0x00000000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.AXIBAR_NUM">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.BAR0_ENABLED">true</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.BAR0_SCALE">Megabytes</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.BAR0_SIZE">64</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.BAR0_TYPE">Memory</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.BAR1_ENABLED">true</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.BAR1_SCALE">Megabytes</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.BAR1_SIZE">64</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.BAR1_TYPE">Memory</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.BAR2_ENABLED">true</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.BAR2_SCALE">Gigabytes</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.BAR2_SIZE">2</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.BAR2_TYPE">Memory</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.BAR_64BIT">true</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.BASEADDR">0x00000000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.BASE_CLASS_MENU">Processors</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.CLASS_CODE">0x0B4000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.COMP_TIMEOUT">50ms</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.Component_Name">axi_pcie_1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.DEVICE_ID">0x1030</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.ENABLE_CLASS_CODE">false</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.HIGHADDR">0x00FFFFFF</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.INCLUDE_BAROFFSET_REG">true</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.INCLUDE_RC">PCI_Express_Endpoint_device</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.INTERRUPT_PIN">true</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.MAX_LINK_SPEED">5.0_GT/s</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.MSI_DECODE_ENABLED">true</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.M_AXI_ADDR_WIDTH">32</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.M_AXI_DATA_WIDTH">128</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.NO_OF_LANES">X4</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.NUM_MSI_REQ">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.PCIEBAR2AXIBAR_0">0x00000000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.PCIEBAR2AXIBAR_0_SEC">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.PCIEBAR2AXIBAR_1">0x40000000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.PCIEBAR2AXIBAR_1_SEC">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.PCIEBAR2AXIBAR_2">0x80000000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.PCIEBAR2AXIBAR_2_SEC">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.PCIE_BLK_LOCN">X0Y0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.PCIE_USE_MODE">GES_and_Production</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.REF_CLK_FREQ">100_MHz</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.REV_ID">0x01</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.SLOT_CLOCK_CONFIG">true</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.SUBSYSTEM_ID">0x0000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.SUBSYSTEM_VENDOR_ID">0x1AEE</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.SUB_CLASS_INTERFACE_MENU">Co_processor</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.S_AXI_ADDR_WIDTH">32</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.S_AXI_DATA_WIDTH">128</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.S_AXI_ID_WIDTH">4</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.S_AXI_SUPPORTS_NARROW_BURST">true</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.VENDOR_ID">0x1AEE</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.XLNX_REF_BOARD">None</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.axi_aclk_loopback">false</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.en_ext_ch_gt_drp">false</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.en_ext_clk">true</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.en_ext_gt_common">false</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.en_ext_pipe_interface">true</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.en_transceiver_status_ports">false</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.no_slv_err">false</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.rp_bar_hide">false</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.shared_logic_in_core">false</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PROJECT_PARAM.ARCHITECTURE">artix7</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PROJECT_PARAM.BOARD"/>
<spirit:configurableElementValue spirit:referenceId="PROJECT_PARAM.DEVICE">xc7a200t</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PROJECT_PARAM.PACKAGE">ffv1156</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PROJECT_PARAM.PREFHDL">VHDL</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PROJECT_PARAM.SILICON_REVISION"/>
<spirit:configurableElementValue spirit:referenceId="PROJECT_PARAM.SIMULATOR_LANGUAGE">VERILOG</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PROJECT_PARAM.SPEEDGRADE">-2</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PROJECT_PARAM.TEMPERATURE_GRADE">C</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PROJECT_PARAM.USE_RDI_CUSTOMIZATION">TRUE</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PROJECT_PARAM.USE_RDI_GENERATION">TRUE</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="RUNTIME_PARAM.IPCONTEXT">IP_Integrator</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="RUNTIME_PARAM.IPREVISION">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="RUNTIME_PARAM.MANAGED">TRUE</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="RUNTIME_PARAM.OUTPUTDIR">.</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="RUNTIME_PARAM.SELECTEDSIMMODEL"/>
<spirit:configurableElementValue spirit:referenceId="RUNTIME_PARAM.SHAREDDIR">../../ipshared</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="RUNTIME_PARAM.SWVERSION">2016.2</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="RUNTIME_PARAM.SYNTHESISFLOW">OUT_OF_CONTEXT</spirit:configurableElementValue>
</spirit:configurableElementValues>
<spirit:vendorExtensions>
<xilinx:componentInstanceExtensions>
<xilinx:configElementInfos>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.AXIBAR2PCIEBAR_0" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.AXIBAR_0" xilinx:valueSource="propagated"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.AXIBAR_AS_0" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.AXIBAR_HIGHADDR_0" xilinx:valueSource="propagated"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.BAR0_SCALE" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.BAR0_SIZE" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.BAR1_ENABLED" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.BAR1_SCALE" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.BAR1_SIZE" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.BAR1_TYPE" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.BAR2_ENABLED" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.BAR2_SCALE" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.BAR2_SIZE" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.BAR2_TYPE" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.BAR_64BIT" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.BASEADDR" xilinx:valueSource="propagated"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.BASE_CLASS_MENU" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.CLASS_CODE" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.COMP_TIMEOUT" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.DEVICE_ID" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.ENABLE_CLASS_CODE" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.HIGHADDR" xilinx:valueSource="propagated"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.INTERRUPT_PIN" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.MAX_LINK_SPEED" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.M_AXI_DATA_WIDTH" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.NO_OF_LANES" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.PCIEBAR2AXIBAR_1" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.PCIEBAR2AXIBAR_2" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.REV_ID" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.SUBSYSTEM_ID" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.SUBSYSTEM_VENDOR_ID" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.SUB_CLASS_INTERFACE_MENU" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.S_AXI_DATA_WIDTH" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.S_AXI_ID_WIDTH" xilinx:valueSource="propagated"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.S_AXI_SUPPORTS_NARROW_BURST" xilinx:valueSource="propagated"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.VENDOR_ID" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.en_ext_ch_gt_drp" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.en_ext_clk" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.en_ext_pipe_interface" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.shared_logic_in_core" xilinx:valueSource="user"/>
</xilinx:configElementInfos>
</xilinx:componentInstanceExtensions>
</spirit:vendorExtensions>
</spirit:componentInstance>
</spirit:componentInstances>
</spirit:design>
venkata
when you say vivado 2016.2 embedded simulator, are you referring to XSIM?
Can you create a .zip file with the .xci and share it?
venkata
I could use the .xci file contents and generate the IP example design. I find the example design simulation run successfully with XSIM. I have sent the example design to you through EZmove.
If you are using a different simulator other than XSIM, please check the compatibility of the simulator version with Vivado 2016.2. Table 2-2 of ug973 (https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_2/ug973-vivado-release-notes-install-license.pdf) provides the Compatible Third-Party Tools.
If you are using the right version of the simulator, please check the simulation libraries are compiled correctly. As a test, you can compile the simulation libraries again in a different location and use them for simulation.
kynthia9
your example works fine, I compared with my rtl, cannot see any difference apart from core name.
the most magic thing is my old example running for 4 hours to come back failure log, yours just a couple of minutes.
I will check mine more, and thanks for your good example.
