tx_err_drop assertion in 7 series PCIe block
I am using Xilinx 7 series PCIe in design.
PG054 says, tx_err_drop is asserted "no later than second clock cycle following axis_tlast".
Does it mean tx_err_drop will be asserted only after axis_tlast or it can be asserted any time the error conditions are encountered(in between a AXI stream transaction)?
Aj.
Re: tx_err_drop assertion in 7 series PCIe block
Yes. Your understanding is correct. tx_err_drop will be asserted only after axis_tlast. The description of the signal behavior also gives you similar understanding.
Transmit Error Drop: Indicates that the core discarded a packet
because of a length violation or, when streaming, data was not
presented on consecutive clock cycles.
