gdliu
where is the xapp1052 for K7?
liy
Please refer to http://www.xilinx.com/support/documentation/application_notes/xapp1171-pcie-central-dma-subsystem.pdf
In this reference design the DMA function is implemented using CDMA core
vijayak
The Xapp1052 is not designed for K7.
Refer to http://www.xilinx.com/support/documentation/application_notes/xapp1052.pdf for details.
Thanks,Vijay
liy
