tbpritchard
ChipScope Pro required for PicoBlaze using Vivado?
The README file for the KCPSM6 Release 7 indicates "When using Vivado 2013.1 or later then it will also be necessary in install ChipScope provided with ISE tools."  Is it required to purchase ChipScope Pro when using a PicoBlaze with Vivado, or all necessary tools available for free (if a logic analyzer isn't necessary)?
vuppala
Yes, you need a chipscope pro license to use.
See this answer record for more information: http://www.xilinx.com/support/answers/42063.htm
Vinay
