paebbels
KCPSM6 on Kintex7 - mapping error
I ported one of my designs from Virtex-5 / Virtex-6 to our new Kintex-7 board. This design employes a PicoBlaze KCPSM6 with constraints.
xst -> all ok
translate -> all ok
map -> error
here is the message:
The directed pack was not possible because: The top reasons for failure were:
-> A legal placement was never found for LUT symbol "PT/SoFPGA/PicoBlaze/address_loop[0].lsb_pc.high_int_vector.pc_lut".
-> A legal placement was never found for LUT symbol "PT/SoFPGA/PicoBlaze/address_loop[1].upper_pc.high_int_vector.pc_lut".
-> A legal placement was never found for LUT symbol "PT/SoFPGA/PicoBlaze/address_loop[2].upper_pc.high_int_vector.pc_lut".
-> A legal placement was never found for LUT symbol "PT/SoFPGA/PicoBlaze/address_loop[3].upper_pc.high_int_vector.pc_lut".
-> The DI signal PT/SoFPGA/PicoBlaze/pc_mode<0> on CYMUX PT/SoFPGA/PicoBlaze/address_loop[0].lsb_pc.pc_muxcy has a conflict with the AX pin and the O5 output of the A LUT is not available for a route-through.
Has anyone noticed a similar error. If I'm not mistaken a 7-Series Slice should be a superset of a Virtex-5/6 Slice....
Best regards
     Patrick Lehmann
Tags (4)
chapman
If this was reported as a 'Pack:2811' error, then yes, this is covered as a 'Known Issue' with workarounds in the 'READ_ME_FIRST.txt' file provided in the KCPSM6 package. If it was something different then I'd need to see and know a bit more information.
KCPSM6 is suitable for use with Spartan-6, Virtex-6, 7-Series and UltraScale devices. I assume you meant that you replaced KCPSM3 with KCPSM6 when moving from Virtex-5; the details in the messages you provided certainly indicate that you are using KCPSM6 in your design now.
Ken Chapman
Principal Engineer, Xilinx UK
paebbels
Sorry for my late response.
I'm actually using KCPSM6 on Virtex-5 (unconstrainted version) as well. There are no problems so far.
Yes, it's a Pack:2811 error. After posting my last message I found several posts in this forum addressing this issue, sorry again.
I also read your post: PicoBlaze FAQ - 'Pack:2811' error in MAP
Regarding your workarounds:
a) ChipScope is somewhere in the design, but not directly connected to the PicoBlaze
b) This was a good point - I recreated the project from scratch and forgot to select/deselect some xst, map and par options. So now xst is again in Keep Hierarchy = Soft mode :)
I also changed two other settings:
- In my ILA IP-Core (ChipScope), I disabled RPMs (relationally placement macros), because the are often related to pack:2811 errors.
- I also had an other mapping problem caused by a GTXE2 transceiver in a Kintex-7 device.
The latter one was hard to find because it generated several mapping errors, which where not really assoziated with the GTXE2 tranceiver. The bug is in the Kintex-7 / KC705 documentation: RX_n and RX_p pins for GTXE2_CHANNEL_X0Y10 are swaped!
So I'm not sure which change fixed the pack:2811 error, but KCPSM6 is working again.
Best regards
     Patrick Lehmann
