finbarrlong
Microblaze - Modelsim loading issue - cannot find .mem file
I created a block diagram using Vivado Version 2013.3, which contains a Microblaze (version 9.2) and ancillary ip components.
I have compiled the complete design in Modelsim (version 12.d and 12.e) but I get the following error when loading modelsim.
# Loading work.system_lmb_bram_0(system_lmb_bram_0_arch)
# ** Fatal: (vsim-7) Failed to open VHDL file "system_lmb_bram_0.mem" in rb mode.
# No such file or directory. (errno = ENOENT)
#    Time: 0 ps  Iteration: 0  Process: /system_wrapper/system_i/microblaze_0_local_memory/lmb_bram/U0/native_mem_map_module/mem_map_module/line__3381
File: c:/Projects/Xilinx/kintex_x4_meet_timing/kintex_x4_sep_pll_gg_pcie.srcs/sources_1/bd/system/ip/system_microblaze_0_axi_intc_0/blk_mem_gen_v8_0/simulation/blk_mem_gen_v8_0.vhd
# FATAL ERROR while loading design
I created a file a .mem file "system_lmb_bram_0.mem" and placed it in the directory
but this did not solve the problem.
Does anyone have any idea where this issue is originating from and as to what possible course of action I could take to rectify it.
Finbarr
achutha
Hi ,
Can you please the mem file in the simulation directory?
.///kintex_x4_sep_pll_gg_pcie.sim/sim1/
Achutha
finbarrlong
Hi Achutha
Yes, I did that but still get the same error.
Finbarr
finbarrlong
Has anyone got any other suggestions?
I even changed the version of Modelsim to most recent version 10.3b, but still have had no luck.
Thks
Fionbarra
