dag1
WINDOWS 64 BIT, IS THERE ANOTHER ASSEMBLER FOR PICOBLAZE BESIDES pBlazASM suite ?
1. WINDOWS 64 BIT, IS THERE ANOTHER ASSEMBLER FOR PICOBLAZE BESIDES pBlazASM suite ? (THE KCPSM3 DOES NOT WORK ON 64 BIT WINDOWS)
2. WINDOWS 64 BIT, Is there another Simulator besides PblazeIDE ? one which can do not only EXPORT from .PSM but also SAVE back to the format of PSM (so that if I do changes in the IDE then I can then compile them using the pBlazeASM ? )
thanks
Dag
paebbels
Maybe you can upgrade to the newest Picoblaze and KCPSM6.
This assembler works fine on windows 64 bit.
There is also a constraint free version of kcpsm6.vhd, which can
be synthesized on older platforms like Virtex-5 as well.
I'm using kcpsm6.exe and notepad++ as editor with user defined syntax highlighting rules.
chapman
Please see the following thread...
KCPSM3 for windows 7 64-bit?
http://forums.xilinx.com/t5/PicoBlaze/KCPSM3-for-windows-7-64-bit/td-p/104539
Ken Chapman
Principal Engineer, Xilinx UK
