jtag loader not working
 I am having some issues getting the jtag loader to work. I am wondering if the directory length matters or not.
I tried to run hex2svfsetup.exe from
"C:\perforce\depot\eni\eng\projects\DEV\E9319_LowPower\P00_System_FPGA\lp_control\src\uc_uart_flash\kcpsm_code"
and it did not work with the following error message
The system cannot execute the specified program.
but it works from
"C:\my_designs"
Any idea why. Thanks
Amish
 yeah you are probably right. I eventually created a batch file and copied all files needed to c:\temp before compiling and uploading the fpga. That seems to work. Thanks for the help.
Amish
Hi Amish
your path has more than 100 chars and only the programmers at xilinx can tell what size they choose for the path variable buffer in their program.
But there's a way how you can deal with this.
Don't use the absolute path.
A relative path from your working directory will do it as well.
e.g (as a script /batch)
#change path to your project directory
cd  C:\perforce\depot\eni\eng\projects\DEV\E9319_LowPower\P00_System_FPGA
#call  hex2svfsetup from here
hex2svfsetup.exe [options] .\lp_control\src\uc_uart_flash\kcpsm_code\yourcode.hex
So the path is reduced to 55 chars. Hope this wors, otherwise you can go deeper with cd and start the tool there.
Have a nice synthesis
  Eilert
Amish
