Anonymous
Not applicable
picoblaze instruction storage
hi ,
  i get one question a few days, that i want to use distributed rom instead of BRAM in picoblaze instruction storage, is there any one knows how to generate this template , thank you so much,
chapman
The .COE file produced by the assembler is there to be used with the Xilinx Core Generator which can in turn be used to produce distributed ROM. Please read page 45 of KCPSM3_Manual.pdf supplied in the PicoBlaze ZIP file to understand 'ROM_form.coe'. I recommend that you simply set the first line to be 'memory_initialization_vector=' and then make all other settings for the ROM in the Core Generator GUI.
Note that a 256 instruction ROM will occupy 144 slices in a Spartan-3 Generation device. That's larger than KCPSM3 (96 slices) so generally you would only do this for small programs, special reasons or where you have lots of spare slices but lack BRAM.
Ken
Ken Chapman
Principal Engineer, Xilinx UK
chapman
Ken
Ken Chapman
Anonymous
Not applicable
hi ken,
  so kindly you are , i tested my program just now and it worked, thank you so much,
jackyye
shangdawei@gmail.com
i t use distributed rom instead of BRAM in picoblaze instruction storage 1K Inst. at Spartan 3S400A
| Module                | Slices | Slice Reg | LUTs   | LUTRAM  | BRAM  | MULT18X18 | BUFG  | DCM   | Full Hierarchical Name       |
| +program_rom          | 0/875  | 0/18      | 0/1249 | 0/0     | 0/0   | 0/0       | 0/0   | 0/0   | picoblaze/program_rom        |
| ++BU2                 | 0/875  | 0/18      | 0/1249 | 0/0     | 0/0   | 0/0       | 0/0   | 0/0   | picoblaze/program_rom/BU2    |
| +++U0                 | 0/875  | 0/18      | 0/1249 | 0/0     | 0/0   | 0/0       | 0/0   | 0/0   | picoblaze/program_rom/BU2/U0
| ++++gen_rom.rom_inst  | 875/875| 18/18     | 1249/1249                                            | picoblaze/program_rom/BU2/U0/gen_rom.rom_inst
Message Edited by shangdawei@gmail.com on 12-04-2009 04:21 AM
