2018.1 FSBL sample fails to build
I'm trying to create an SD card with and ELF and BIT, so we can test a board without XSDK, etc.  I follow the steps on the wiki, but get some errors using the example application.  It seems some symbols aren't defined (psu_ps_pl_isolation_removal_data and
psu_ps_pl_reset_config_data).  I think these are functions in psu_init.c (at least they seem to be in mine), but they are not linking despite the HW_platofrm being in the include path.
So, any ideas why these aren't getting linked?
I have tested this real quick on my end. I used a tcl script below to create the workspace:
Note: The script can be sourced on the XSCT console.
proc create_workspace {hdf} {
   setws project_1.sdk
   set hw_platform "[file rootname [file tail $hdf]]_hw_platform_0"
   createhw -name $hw_platform -hwspec $hdf
   createapp -name fsbl -app {Zynq MP FSBL} -proc psu_cortexa53_0 -hwproject $hw_platform -os standalone
   projects -build
create_workspace [glob -directory [pwd] *.hdf]
The steps to do this manually are shown in my last post. This builds without issue. I can open this in the GUI, and everything looks fine.
 If you look below, you will see how the psu_init.c is added to the application. The file is shared from the hardware platform. In your case, this path seems to be broken. Can you verify this?
Do you see any issues with any other application (like the hello world). I suspect this issue is with your TEMP directory in SDK.
Does this have proper read/write access?
Can you post your error you are seeing?
These functions are in the psu_init.c. The psu_init.c is in the hw_platform. Did you create the HW platform in SDK?
So, lets start from scratch...
Launch SDK
Create HW platform
  • File -> new -> project -> Xilinx -> Hardware Platform specification, and browse to your HDF file that was created when you exported to SDK from Vivado
Create the FSBL
  • File -> New -> Application Project, give it a name, Next, and select the FSBL template and Finish
  • (Optional) Right Click on the fsbl applciation, and select C/C++ build settings. Then in the symbols, select and add "FSBL_DEBUG_INFO"
Create the Bootable image:
  • Right click on the fsbl application in Project explorer view in SDK, and select create boot image.
  • The fsbl, and bit (if exists in hw platform), should be auto-populated. If not add the fsbl as the bootloader, and the bit as a data file. Select next to continue.
Boot:
Place the boot.bin onto your SD card, and set the boot mode to boot from SD card
Thanks for replying,
I've tried again with the instructions provided and I'm still getting errors.  This time I just the BSP generated rather than my own.  In the errors tab I get:
make: *** [FSBL_ZCU_10_5_FSBL.elf] Error 1 FSBL_ZCU_10_5_FSBL C/C++ Problem
In the console I see:
aarch64-none-elf-gcc: error: ./FSBL_ZCU_10_5_FSBL_bsp/psu_cortexa53_0/libsrc/spips_v30/src/xspips_g.o: No such file or directory
In this case it looks like there is a problem with the path generated it is ..../spips_v30... rather than ..../spips_v3_0/...  Not sure I can override that because it's coming from an auto generated makefile right?
When doing what I did before (the same but using my own BSP), I get the following errors in the console:
'Building target: FSBL_ZCU_10_5_mybsp.elf'
'Invoking: ARM v8 gcc linker'
aarch64-none-elf-gcc -Wl,-T -Wl,../src/lscript.ld -LC:/Users/Adam/Documents/code/BSP_ZCU_4_5_2018/BSP_ZCU_4_5_2018/psu_cortexa53_0/lib -o "FSBL_ZCU_10_5_mybsp.elf"  ./src/xfsbl_authentication.o ./src/xfsbl_board.o ./src/xfsbl_bs.o ./src/xfsbl_csu_dma.o ./src/xfsbl_dfu_util.o ./src/xfsbl_exit.o ./src/xfsbl_handoff.o ./src/xfsbl_hooks.o ./src/xfsbl_image_header.o ./src/xfsbl_initialization.o ./src/xfsbl_main.o ./src/xfsbl_misc.o ./src/xfsbl_misc_drivers.o ./src/xfsbl_nand.o ./src/xfsbl_partition_load.o ./src/xfsbl_plpartition_valid.o ./src/xfsbl_qspi.o ./src/xfsbl_rsa_sha.o ./src/xfsbl_sd.o ./src/xfsbl_translation_table.o ./src/xfsbl_usb.o   -Wl,--start-group,-lxil,-lgcc,-lc,--end-group -Wl,--start-group,-lxil,-llwip4,-lgcc,-lc,--end-group -Wl,--start-group,-lxilffs,-lxil,-lgcc,-lc,--end-group -Wl,--start-group,-lxilpm,-lxil,-lgcc,-lc,--end-group -Wl,--start-group,-lxilsecure,-lxil,-lgcc,-lc,--end-group -n
C:\Users\Adam\AppData\Local\Temp\ccdzr4Zt.ltrans0.ltrans.o: In function `XFsbl_PartitionValidation.constprop.7':
<artificial>:(.text+0x295c): undefined reference to `psu_ps_pl_isolation_removal_data'
<artificial>:(.text+0x295c): relocation truncated to fit: R_AARCH64_CALL26 against undefined symbol `psu_ps_pl_isolation_removal_data'
<artificial>:(.text+0x2960): undefined reference to `psu_ps_pl_reset_config_data'
<artificial>:(.text+0x2960): relocation truncated to fit: R_AARCH64_CALL26 against undefined symbol `psu_ps_pl_reset_config_data'
C:\Users\Adam\AppData\Local\Temp\ccdzr4Zt.ltrans0.ltrans.o: In function `main':
<artificial>:(.text.startup+0xe8): undefined reference to `psu_init'
<artificial>:(.text.startup+0xe8): relocation truncated to fit: R_AARCH64_CALL26 against undefined symbol `psu_init'
<artificial>:(.text.startup+0xfcc): undefined reference to `psu_ps_pl_isolation_removal_data'
<artificial>:(.text.startup+0xfcc): relocation truncated to fit: R_AARCH64_CALL26 against undefined symbol `psu_ps_pl_isolation_removal_data'
<artificial>:(.text.startup+0xfd0): undefined reference to `psu_ps_pl_reset_config_data'
<artificial>:(.text.startup+0xfd0): relocation truncated to fit: R_AARCH64_CALL26 against undefined symbol `psu_ps_pl_reset_config_data'
<artificial>:(.text.startup+0x104c): undefined reference to `psu_protection'
<artificial>:(.text.startup+0x104c): relocation truncated to fit: R_AARCH64_CALL26 against undefined symbol `psu_protection'
<artificial>:(.text.startup+0x1054): undefined reference to `psu_protection_lock'
<artificial>:(.text.startup+0x1054): relocation truncated to fit: R_AARCH64_CALL26 against undefined symbol `psu_protection_lock'
collect2.exe: error: ld returned 1 exit status
make: *** [FSBL_ZCU_10_5_mybsp.elf] Error 1
These are again makefile based, so I guess something is generating incorrectly.  These methods are definitely in psu_init.  It is linked as a workspace path.  When I remove this include path it fails to find pus_init.h, so it is definitely getting parsed.
Can you post your HDF file please?
Sure, I've pm'd you a link
   setws project_1.sdk
   projects -build
Ok, thanks for that, you were right.  There seems to be a path problem when sharing the psu_init.c.  When I manually copied it across everything worked fine.
I tried creating a hello_word project just to check and it worked fine.  I have had problems with the SDK before (generating wrong addresses in x_params etc.).  It should have read/write permissions no problem, it is on a different hard drive to the code and workspace, but that shouldn't matter.
In any case, thanks a lot.  I'll finish off the SD card now.
