4 UARTs interfacing with Zynq processor
Hi all,
We need to implement 4 UARTs with zynq ps in one of our project. For zynq processor only 2 UARTs support is there. Is there any procedure to 2 UARTS interfacing to PL but the output will be from PS side
please suggest me
Thanks in advance
Hi @akarshana,
I'm not sure if I am misunderstanding something, but implementing two UARTS in the PL and control them from the PS is really straightforward.
You only have to create a BD where you have two UARTs connected to the AXI bus and then use the xilinx uart drivers as same as the PS integrated UARTs.
Ibai
Ibai
Hi @akarshana,
Ibai
Ibai
Is there any reference example for this? if there, please provide me.
