rsclancy
AXI 1G.2.5G Ethernet Subsystem PG138 Typo?
In version 7 of PG138 on page 35 in table 2.3 which discusses reading a PHY register via the MII interface there appears to be a typo. The example describes reading from REGAD b00001 but the register value "Value" column in the table is set to b00010. Also the text in the Activity box might be clearer if it read something like "initiate the read by writing to the MII Management Control Register". Is this in fact a typo?
