Raf
AXI 4 stream VIP if
I'm using VIP for my slave AXI4stream.
The TB works but if I want to add Wilinx config. checks (XILINX_AXI4STREAM_ERRM_RESET_PULSE_WIDTH) for example, what I've to do?
I downloaded XILINX  XAM_UVC  API but seems they cannot be integrated in my TB.
I'm using Vivado 2020.2. I didn't found docs about it.
Tags (2)
florentw
Hi @Raf
The VIP should do the checks. If the interface is not behaving as expected, there should be an message in the console window.
The following article can guide you:
https://forums.xilinx.com/t5/Design-and-Debug-Techniques-Blog/AXI-Basics-4-Using-the-AXI-VIP-as-protocol-checker-for-an-AXI4/ba-p/1062002
Florent
florentw
Hi @Raf
Florent
Raf
Thanks Florent, it works.
Best regards
Raffaele
