bader@gctnet.de
AXI BRAM Controller Problem
When i first work with a ZEDBaord everything is fine but now I use the zcu102 Board, and I cannot change my BRAM-Interface anymore. Everything is gray out, and it is definitly wrong, as you can se inb the picture.
Validate design doesn't change anything, the BRAM controller stays fixes at 65536.
( on the left lower corner is the setting )
Can anyone tell me how to fix this ?
Thanks in advance
klasha
You likely have configured your Block Memory to use BRAM-Controller Interface mode.
This means that the BRAM will be configured like your BRAM Controller wants it (32/64/128-Bit Interface, memory size)
You can change the size of the addressable memory in the Address Editor - The size will be automatically configured once you validate your IP Integrator design.
bader@gctnet.de
Hmmm, no one knows anything about this ?
I have build a new project, and it's getting worse.
Now the size is 16384,
My BRAM is 65536 * 32. Everything compiles fine, only my software crashes, because of the missing memory.
Can anyone explain me how to correctly ( and where ) set these values ?
PS.: I am using a ZCU102 Eval-Baord
klasha
bader@gctnet.de
You are right. The trick is to change the size in the address editor BEFORE validating the design.
