AXI CDMA in Scatter-Gather mode. Could some please explain it's purpose.
I started to implement AXI CDMA core into my design and would like to ask few questions. First of all, I went through a CDMA manual but I didn't understand everything. I understand how does a CDMA in a Simple mode work, but I don't understand the purpose of so called "scatter-gather" mode. Could someone please explain when is this feature good to use and what are the benefits compared to the normal (simple) mode?
In my case I would like to transfer data from FIFO (when a sufficient number of bytes is available, let say 1 kB) to the another AXI slave. New transfer over DMA should start as soon as new 1 kB of data is available in FIFO. Here, I would like to involve the CPU (Microblaze) as little as possible.
Thank you a lot.
Matic
Re: AXI CDMA in Scatter-Gather mode. Could some please explain it's purpose.
@matic not necessarily. If they are both memory-like and they have defined addresses of blocks where you copy from/to then yes. But it depends on how these interfaces are supposed to be accessed.
@matic When you say "transfer to another AXI slave" I assume you want to transfer from FIFO to AXI MM-slave.
CDMA will not do what you want. CDMA will transfer from AXI MM to another AXI MM.
You need a component to move from AXI stream (fifo) to AXI memory address (slave). This is the AXI DMA.
https://www.xilinx.com/support/documentation/ip_documentation/axi_dma/v7_1/pg021_axi_dma.pdf
Scatter gather is just programming several transfers in advance instead of just one. It is useful because the engine will always be working in the background. In single shot mode, there is a gap between the end of one transfer and configuring a new one and data might get dropped.
When you kick off a transfer it will start storing bytes as often as they come, unless you find a way to hold them in your component. I really see no reason why the DMA should hold on bytes waiting for them to accumulate instead of storing them right away.
Yes, no CPU work is involved in the process other than configuring the DMA and starting the engine.
@hbucherThank you for your reply.
Yes, the AXI slave is memory mapped slave.
In the previous design (without microblaze), I had implemented my own FIFO (not one from the IP catalog). Now, when I want to use (C)DMA, I thought to map an output port of my own FIFO as one addressed register in a customized AXI slave and do a DMA transaction between those two memory mapped AXI slaves.
If I understand you correctly, you suggest that I fill the "proper" AXI FIFO (from IP catalog) with my data and then do a transaction between that AXI FIFO and a destination AXI MM-slave in a stream manner (using DMA engine). Could you confirm this?
If that is true, I found out that there are several AXI FIFOs in the IP catalog. I see there "AXI-4 Stream FIFO" , "AXI-4 Stream Data FIFO" and "AXI Data FIFO". Which one should I use for that purpose?
Thank you again.
@matic No, I am not saying that. Even because I am having a hard time to understand what you are trying to accomplish.
I just said that if you have to send data to an AXI-stream interface, AXI CDMA is the wrong component.
@hbucher  I am reading data from the encoder, which is externally connected to the FPGA. This "reader" is a customized logic which is packaged into an IP block and connected to a Microblaze via AXI interface. Actually it is an AXI (full) MM-slave.
Here, Microblaze is used for data processing. But in some cases I want to transmit data directly to another IP (as fast as possible, without involving CPU). This another IP is also a customized IP and it serves for a communication to a PC. This IP is feeding data into FTDI chip which communicates to the PC via USB 2.0.
So, I would like to tranmit bytes which are constantly being read by my encoder reader to the other IP which is sending data over FTDI chip to the PC. I assume that I should have some kind of FIFO in between these two IPs and transmit data (bytes) from FIFO to the second IP (for output) via DMA.
Could you recommend something based on this description? Thank you
@matic Are those AXI or AXI-stream interfaces?
@hbucher
Both of them are AXI interfaces.
@matic then you need to have a processor dealing with these two interfaces. A fifo has streaming interfaces.
@hbucher
So, then I could use CDMA to transmit data between those two AXI MM-slaves. Am I correct?
I really appreciate your help.
