09-09-2016 05:12 AM
I am trying to get the cyclic descriptor functionality working with the axi_dma core in scatter gather mode.
I have tried this in simulation and so far it just stops at the last descriptor in the chain.
My simulation does the following in this order:
- Write descriptor table to memory
- Write first descriptor address to CURR_PTR
- Set Cyclic BD bit in control register
- Set Interrupt enable bits and the DMA engine start bit in the control register (separate write to previous step)
- Read back control reg and check this has had effect.
- Write address of last descriptor to TAIL_PTR
I have also tried setting the tail pointer to an address not in the chain (the example gives 0x50 as a suggestion), and this doesn't seem to work either.
I am using Vivado 2014.2 and have checked the changelog up to 2016.2 for anything related to this (post 2014.2) and see nothing.
Help?
09-13-2016 04:26 AM
Ok, I have managed to make the DMA engine do what I want, but I have cheated slightly.
In my implementation:
- The DMA engine wraps around to the first descriptor once the last has been processed.
- At any point if the DMA engine reaches a stale descriptor it stops.
To do this you need to do the following:
- Disable Cyclic BD mode
- Make the last descriptor point back to the first.
- Program the Tail Descriptor with an address outside of the range used by the descriptors. In my case the last descriptor is at address 0x8000_0100 so I make my Tail Pointer 0x8000_0140.
Basically in non-cyclic BD mode the engine stops once the current pointer is >= the tail pointer. If the last descriptor points back to the first and the tail is greater than the last descriptor address then this never happens....
Worth knowing.
09-09-2016 08:39 AM
Could I also clarify what I understand to be the two modes of operations in Scatter Gather mode.
1. No cyclic BD
In this I program the start and end pointer to the descriptor chain. When the end of the chain is reach the DMA engine halts and to restart it (by writing to the tail pointer?)I must make the descriptors not stale and then write one to bit DMACR.RS. This is true even if my last pointer points back to the first descriptor and I have cleared that first descriptors completed bit.
2. Cyclic BD
Here I set up the chain so that the last descriptor points back to the first. To start the DMA engine, I write an address to the tail pointer that is not part of the descriptor table. The engine wraps round back to the first pointer after it has processed the last and ignores whether any of the descriptors are stale.
So, assuming all this is true, I would prefer a third method that doesn't seem to be available.
- the DMA engine should not halt when it reaches the tail pointer descriptor, provided I have set it up to cyclicly wrap back round to the first pointer.
- The completed bit's should not be ignored. The engine can halt if it reaches a stale descriptor.
- My software will clear these bits as the application reads the data already written.
- My software will do this often enough to ensure that the engine does not encounter any stale descriptors.
This ensures that the engine carries on without need the software to restart it by writing to the tail pointer once the end of the descriptor chain has been reached, provided the descriptors are refreshed often enough.
Can someone confirm that this is not possible with the current version of the core and if so can I request it as a new feature?
09-09-2016 01:34 PM - edited 09-09-2016 01:37 PM
Your descriptions in 1 and 2 are correct. The only caveat may be your last statement in 1.
I have never tried this. If you clear the completed bits via SW before the DMA gets back to that descriptor, it may still keep going.
Essentially, cyclic mode is implemented (to my knowledge) by the DMA simply ignoring the IOC bits in any given BD so if you point the tail descriptor back to the beginning, it'll keep going in cyclic mode.
So, assuming all this is true, I would prefer a third method that doesn't seem to be available. ...
You are correct that this method you described is not possible based on the way I described how cyclic mode works above (with the possible caveat above that might work).
Maybe I'm missing it, but what would be the need for this third method? In either case, your software needs to react fast enough to consume the data before the DMA starts overwriting itself (or aborts).
Anyway, can you post some screenshots of your simulation showing BD setup and the DMA stopping on the last one?
Have you checked status registers for any errors when it halts?
09-12-2016 02:05 AM
Thank you bwiec for looking into this for me. I'll give as much detail as I ca nto try and help chase it down.
Here is my BD layout. Ignore the translational BRAM. This is a leftover from the CDMA approach I started with. It's not use with the standard DMA engine. The descriptors for this don't allow source/dest address pairing to be specified, so I can't insert address descriptors in the middle of my chain to update the translation registers. I don't think I need to do this anyway.
Here is my descriptor chain. The chain is stored on the host PC side. The base address for this memory region, translated to the axi side, is 0x8000_0000. The base address for the memory region that will receive the data on the host PC side is 0x6000_0000.
Each descriptor is set up to transfer the same numbe rof bytes, 0x0160, and each packet I attempt to transfer is less than this. the last descriptor points back to the first.
Descriptor 1
Addr: 0x8000_0000
Next Descriptor Ptr: 0x 8000_0040
Buffer Addr: 0x6000_0000
Control: 0x000_0160
Descriptor 2
Addr: 0x8000_0040
Next Descriptor Ptr: 0x 8000_0080
Buffer Addr: 0x6000_0168
Control: 0x000_0160
Descriptor 3
Addr: 0x8000_0080
Next Descriptor Ptr: 0x 8000_00C0
Buffer Addr: 0x6000_02D0
Control: 0x000_0160
Descriptor 4
Addr: 0x8000_00C0
Next Descriptor Ptr: 0x 8000_0100
Buffer Addr: 0x6000_0438
Control: 0x000_0160
Descriptor 5
Addr: 0x8000_0100
Next Descriptor Ptr: 0x 8000_0000
Buffer Addr: 0x6000_05A0
Control: 0x000_0160
Here is my simulation setup with regards to the DMA:
I will describe the results of my tests below...
09-12-2016 03:59 AM
@bwiec wrote:
first descriptors completed bit.I have never tried this. If you clear the completed bits via SW before the DMA gets back to that descriptor, it may still keep going.
This did not work. As per the PG, the engine goes IDLE once it processes the last descriptor, even though it points back to the first and I have cleared the complete bits before it gets there.
Upon idling the CURRDESC and TAILDESC regs are both 0x8000_0100, the Control Reg is 0x0001_4003 and the Status Reg is 0x0001_100A
Here is the simulation snapshot. You can see the 5 AXI-stream transactions and their associated AXI4 transactions into the axi-pcie core. No interrupt is raised.
This is as I would expect from the description in the Product Guide.
09-12-2016 07:43 AM - edited 09-12-2016 08:13 AM
Ok, so I have actually got the cyclic BD mode working in my simulation now.
I will now describe what happened in a couple of different scenarios and how I fixed it. Again, I have the last descriptor pointing back to the first, and I am clearing the complete bits as they get set as before.
Scenario 1.
TAIL_DESC set to 0x8000_0100 (the last descriptor).
The outcome is actually exactly the same as with the non-cyclic BD example I gave above. The engine IDLEs after the 5 descriptors have been processed. After it idles CURRDESC = TAIL_DESCR = 0x8000_0100, Control = 0x0001_4013, Status = 0x0001_100A.
The screenshot is the same but here it is for reference.
Scenario 2.
TAIL_DESC set to 0x8000_0050 (as suggested in the PG). The engine IDLEs after the first 2 descriptors have been processed. I am assuming this is because the tail pointer is between the address for the second and third descriptors.
After it idles CURRDESC = TAIL_DESCR = 0x8000_0400 (the second descriptor), Control = 0x0001_4013, Status = 0x0001_100A.
Scenario 3
TAIL_DESC set to 0x8000_0250 (an address completely outside the descriptor chain). The engine IDLEs after 6 descriptors have been processed. This is all 5 descriptors and then the first descriptor again. The RP seems to have paused waiting for a completion from a read to one of the DMA registers....
Scenario 4 (the fix)
I then discovered why the RP halted. By this time the RP was receiving fairly large data packets (0x160 size), read requests for the descriptor table and also completions with data in response to read requests for the DMA registers.
This resulted in two back to back TLPs with no gap in between. The problem is that the SOF of the second packet occurred in the same clock cycle as the EOF of the first packet, so the 128-bit data window actually contains data from two adjacent packets. This is allowed but not dealt with by the testbench. In pci_exp_usrapp_rx.vhd you will find:
case trn_sofn_eof_n is when 11 => ... . some code when 01 => ... . some code when 10 => ... . some code when 00 => null end case;
That last option is the problem case.
I tried to fix the testbench but there is actually a lot of changes needed to make it work. So, for now, I have made the data transfers much smaller. This ensures that the data transfer has finished before another packet comes along to be processed and this situation doesn't occur. Having done that the cyclic mode continues indefinitely as expected....
On another note, the PG might need to be a bit clearer when describing what to do with the TAILDESC in cyclic BD mode. It suggests using an address not in the chain, and that it is only used to start the engine (the example is to use 0x50 when the tail is at 0x1C0). However this did not work for me, presumably because 0x50 is in the address range used by my chain, although it isn't one of the start addresses. It actually has to be completely outside of the address range used (0x250 for me), which is not what is suggested. It is not true that "The Tail Descriptor register does not serve any purpose and is used only to trigger the DMA engine" as it says in the PG....I would change this wording.
09-12-2016 07:54 AM
I see your point, but I'l try and explain.
At the moment in cyclic mode the chain wraps around but does not stop if a stale descriptor is encountered, which is a situation you might want to avoid.
You can only avoid this in non-cyclic mode. But here, once the end of the chain is encountered, the software has to react quickly to reset the engine and allow it to start from the beginning. This is highly time critical, if it isn't done quickly data will be lost at the input to the axi4-stream side of the dma core. In our application the data is real time so a long delay here will lose data (a FIFO will fill up somewhere).
You say that the PC software has to work fast enough to catch up with the descriptors anyway. This is true on average, but it can be bursty. I'm not sure our software would normally guarantee a response time, but with a suitably large chain it doesn't need to (in our case it would take 100s of ms to complete the chain). It only needs to have cleared the complete bits on the first part of the chain, so that the engine is able to wrap round until the end. Effectively it treats the wrap around as if it were in the middle of the chain in a non-cyclic mode.
Does this make sense?
09-13-2016 04:26 AM
Worth knowing.
05-02-2017 12:28 PM
Hi @mistercoffee,
I am having a similar problem and trying to set up a simulation to be able to debug it. I was hoping to be able to see what's going on inside of the AXI_DMA core but it seems that the core sources are somehow treated differently and I am not able to add any of the internal signals to the waveform. Looking at your screenshot, I can see that you were able to view some state machine's state. Can you share how you did it? Also, which state machine is that? I searched through the sources for the states in the diagram (WAIT_FOR_READY, ASSERT_LAST) but couldn't find them anywhere. Or, is this your state machine?
/Mikhail
05-03-2017 02:22 AM
@mmatusov wrote:
Hi @mistercoffee,
/Mikhail
ooh, going back a little and I haven't touched the project much since but I will try and help.
I definitely used the AXI to memory mapped PCIE core. But, I think had to use a testbench for the standard 7series Integrated Block as I don't think there was one available for the axi version (at least for PIPE mode which is a must).
As far as the core goes I am using it with "Include Shared Logic (Clocking) in the example design" ticked. That may make a difference.
The state machine (under DMA AXI Stream) is my own state machine that I use to control data flow into and out of the AXI interface.
The other signals in my screenshot look like either external AXI signals, within my block design but outside the PCIE core, or test bench signals (from the example design).
I hope that helps.
05-03-2017 07:45 AM
Hi @mistercoffee,
Thank you for your response. At the moment I am not looking at the PCIe side of the things at all. The test bench I am using is basically the Xilinx test bench for the AXI_DMA and the memory attached to it is in BRAM. I am just trying to make sense out of the S2MM DMA behaviour in the simplest case where I have MM2S looped back to S2MM and a single descriptor in each direction without cycling.
I was actually able to add internal AXI_DMA signals to the waveform, so there is a hope that I can figure it out.
/Mikhail
06-06-2017 08:35 PM
Hi Fellow FPGAers,
I am having the same problem. I am using Vivado 2016.2 with a MicroZed 7Z010 board, got
the AXI DMA loopback "more or less" working. I modified the example app from the SDK directory
to send packets endlessly. The trouble is, the loop gets stuck once the lesser of the Tx or Rx Bd
ring runs through all the buffers and reaches the end.
The last buffer's next pointer does point to the first buffer. But it seems the used ones are not
returned to the ring.
Please help to examine the attached c file, and advice what I missed.
Thank you very much. Best regards,
06-07-2017 01:20 AM
Are you in non-cyclic mode? If so, are you refreshing the descriptors after you've processed them? I found that in cyclic mode you don't have to do this and the ring never halted.
06-07-2017 08:18 AM
Hi MisterCoffee,
Thank you very much for your response.
I tried to call, or not call,
XAxiDma_SelectCyclicMode(TxRingPtr, 1, 1);
XAxiDma_SelectCyclicMode(RxRingPtr, 1, 1);
but got the same behavior: the DMA stops once it reaches and uses the last BD in the shorter
ring (Tx or Rx). It is strange that the longer ring seems to be truncated to the same length
-- I missed to mention this in the first post.
So, it seems I am using the cyclic mode, but I am not sure.
How do I refresh the descriptors? Could you please browse my C file and advice?
Thank you again, best regards,
06-07-2017 08:24 AM
@fpgaioc wrote:
Hi MisterCoffee,
I would but I'm afraid I probably wouldn't be much use. I have only been using the core in simulation with VHDL and verilog testbenches at a low level. Sorry!
03-06-2018 04:35 AM
I am trying to make PCIe project. I can utilize some help from your project.
does your project for PCIe works?
Can you forward me the project?
thanks
06-21-2019 07:01 AM
Hello @mistercoffee , @bwiec
We're currently trying to get cyclic dma working, and by searching I came accross this very interesting forum post.
I'm not a (V)HDL expert, I can do some basic simulation. For AXI4-Lite I use a BFM that I copied from a Silica tutorial , but I've always wondered how other people do use AXI busses, or access / init memory from their testbenches...
I hope you could explain me how you can simulate that whole BD, setup the DMA descriptors in memory, and how you write to all these registers, as you described in that post :
I dont want to ask too much of your time, but if you could give me some hints/clues, I can probably find my way out. Like :
Q1) I expect you first create a hdl wrapper around the bd, and then use that wrapper file as the UUT in your testbench?
Q2) how do you write to all the registers? Like PCIE address translation registers or S2MM_CURDESC ?
Q3) how do you write / init the descriptor list in memory? from a memory init file or also some 'write' function?
06-21-2019 07:19 AM
Hi Ronny,
It sounds like you're ultimately trying to figure out how to simulate a moderately complex set of AXI Lite transactions which would normally come from a processor/software.
There are a number of approaches to do this like:
- AXI BFM/VIP IP from Xilinx
- AXI Traffic generator IP from Xilinx
- Some custom AXI Lite traffic generator with behavioral HDL (honestly, for quick and dirty register reads/writes, I usually just do this. AXI Lite is not that complex)
- Simulate with microblaze
In this case, though, I'd recommend just using the AXI DMA example design that comes with the core :). It is simulatable and shows driving the SG interface. From what I recall, it uses an AXI BRAM on the SG interface. The BRAM contents are loaded with a .coe file that lays out the BD in memory at the correct address offsets that the AXI DMA SG engine is going to look for. Then there's a little state machine to configure/monitor axi lite registers.
06-21-2019 08:03 AM
If I remember correctly the AXI DMA example design uses AXI Traffic generator to simulate all AXI transactions. I found that it was very difficult to modify this test bench, which I needed to do when I was debugging cyclic operation. AXI Traffic generator is only good for sending a stream of AXI writes or reads but it can't for example wait for a result of a read operation and do something different based on the read data. Instead I used a free AXI4-Lite BFM from bitvis. I think it is a much simpler alternative to the Xilinx's own BFM and it saves you from writing your own custom AXI4-Lite models.
/Mikhail
