AXI DMA example tcl script is not working for vivado 2019 version to create project
I want to create the AXI simple transfer using DMA examle of https://www.xilinx.com/support/answers/57561.html.
The tcl script attached with above link answer  is not working to create a new project in version vivado 2019. It shows error that the script was created for version 2013.
Can any one please provide me a zipped complte project of this dma in vavado 2019 or a new script written for vivado 2019 version.
Thank you.
Hitesh.
katsuki
Hi @hitesh.mandaliya
If already issue has resolved, please Give Kudo or Mark the Answer as Accept as Solution and close this thread.
If you have any questions, you can post them.
Thank you.
Don’t forget to reply, kudo, and accept as solution. If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs
katsuki
Hello @hitesh.mandaliya
I don't have a ZC702 right now so I haven't tried it, but is it possible to upgrade the project with VIvado's Upgrade feature?
When you open the project, select "Automatically upgrade".
After that, you should be able to upgrade using the Upgrade button below.
Thank you
Please mark the Answer as Accept as Solution if information provided is helpful.
katsuki
Thank you.
