AXI DMA in SG mode : Size of packets
Hi guys!
Does anyone know how big our packets can be in hardware? Which hardware option affect our MAX_PACKET_LEN define in software? So basically, what is connection between hardware and this software define?
Thanks in advance!
Re: AXI DMA in SG mode : Size of packets
The 'Width of Buffer Length Register' setting in the hardware configuration GUI limits the maximum value you can specify for a transfer length in a single BD.
www.xilinx.com
www.xilinx.com
That is something that I thought initially, but I got different idea when I saw this answer:
https://forums.xilinx.com/t5/Embedded-Processor-System-Design/Axi-DMA-correct-parameters/td-p/639576
According to this, Width of Buffer Length Register defines the maximum size of the entire transfer transaction... :/
