Shanmugam
AXI -DMA is not accessible in linux
I'm using ZCU-102, which is having PL logic  to perform DMA operations using AXI.
Issue: AXI VDMA - device has no channels while booting and unable to run axidmatest.
With reference to Linux Soft DMA Driver , in DTB, AXI DMA shall be in below format
axi_dma_1: dma@40400000 where as DTB generated using my XSA contains dma@a4000000.
a4000000 is the base address provided in PL design.
Compilation Setup : Petalinux 2019.2
Attached DTB, Boot log files and PL design block diagram.
Kindly suggest any solution to access the AXI DMA in PS.
Thanks in advance.
Lordlothard
Hi ,
I'm also working to make axidmatest work. I saw some problems regarding your deign :
1 : You have not connected mm2s and S2mm interrupts . That's why you have these messages when booting :
[ 3.762324] xilinx-vdma a4000000.dma: Please ensure that IP supports buffer length > 23 bits
[ 3.770770] xilinx-vdma a4000000.dma: unable to request IRQ 0
[ 3.776520] xilinx-vdma a4000000.dma: unable to request IRQ 0
[ 3.782260] xilinx-vdma a4000000.dma: dma_async_device_register: device has no channels!
[ 3.790342] xilinx-vdma a4000000.dma: Xilinx AXI DMA Engine Driver Probed!!
2. Personnaly I did not use FIFO I just connect directly DMA in loopback ( S_AXIS_S2MM to MAXIS_MM2S) . Don't know it is an error or not .
3. I can't see the test client in your Device tree !  you should add it manually
 /* Node for axidma test client*/
   axidmatest_1: axidmatest@1 {
      compatible ="xlnx,axi-dma-test-1.00.a";
      dmas = <&axi_dma_lpbck 0
      &axi_dma_lpbck 1>;
      dma-names = "axidma0", "axidma1";
 In System-user.dtsi. Adapt the names with your project.
Then I can't help you more as i failed to make the axidma test run too .  I followed the instructions in Linux Soft DMA Driver - Xilinx Wiki - Confluence (atlassian.net)  :
Running the dmatest client will display the message when the test is successful,
echo 1 > /sys/module/dmatest/parameters/verbose
echo dma1chan0 > /sys/module/dmatest/parameters/channel
echo 2000 > /sys/module/dmatest/parameters/timeout
echo 1 > /sys/module/dmatest/parameters/iterations
echo 1 > /sys/module/dmatest/parameters/run
[ 359.611486] dmatest: Started 1 threads using dma1chan0
[ 359.617245] dmatest: dma1chan0-copy0: result #1: 'test passed' with src_off=0x830 dst_off=0x368 len=0x3560 (0)
[ 359.629924] dmatest: dma1chan0-copy0: summary 1 tests, 0 failures 77 iops 1002 KB/s (0)
When i type these commands nothing happened for me ...  If you have some more info I would be verry happy to read you progression !
Sincerely,
Gautier.
