AXI Direct Memory Access: Determining width of buffer length register in SW
I previously reported this a few years ago to Xilinx.
For the AXI Direct Memory Access IP, with scatter gather turned off (use case), there is a "Width of Buffer Length Register" field with a default of 14.
However, I see no evididence of this parameter being passed to xparameters.h.
Either there should be a #define so that the maximum size of the buffer can be determined in software, or there should be a hard coded register in the IP so that this length can be determined.
The maximum transfer size seems to be 2**WOBLR-1.
But if the HW engineer updates it, how is the SW engineer supposed to know?
BTW, if you exceed the maximum transfer size, the DMA interrupt code just hangs in SDK, without any indication.
This can clearly lead to wasted time and red herrings during code development, which means it will take Xilinx customers longer to get their products to development, and for Xilinx to realize volume revenue.  I know this is obvious to Xilinx, but I wanted to provide a justification here to raise the issue since I have seen no evidence of progress on this apparently small detail that can cause engineer-hours to be spent unnecessarily.
Hi @maps-mpls,
This parameter was added to xparameters.h. The AXI DMA IP added support for 64MB transfers in 2018.1 and the bare metal drivers were upgraded to use this parameter in 2018.2.
The parameter you are looking for in xparameters.h is XPAR_AXI_DMA_0_SG_LENGTH_WIDTH. The width applies in both simple mode and scatter gather mode.
Deanna
Hi @maps-mpls,
Deanna
