AXI IIC scl sda pins always low?
Hi All,
  we are using AXI i2c in Zynq PL  Side which is going to FMC card, in fmc card we have a pullup with 4.7k.
pins:
AJ29 :SDA  ,AJ28 :SCL we hace used,
after programming sda and scl pins are in Low?
So please give support on the above issue is it with IP configuration?
Re: AXI IIC scl sda pins always low?
Hi @jitendra123 ,
Could you please check your constraints for those two signals? I hope the pull ups are missing in constraint file it seems.
Best regards,
Srikanth
