AXI IIc XIic_SetStatusHandler
  I had a microblaze design with peripheral AXI IIC.  In the SDK, I used the example code
xiic_repeated_start_example.c to try the function of AXI IIC. For interrupt function, C code has three interrupt handles:
static void SendHandler(XIic *InstancePtr);
static void ReceiveHandler(XIic *InstancePtr);
static void StatusHandler(XIic *InstancePtr, int Event);
The SendHandler and ReceiveHandler could be triggered successfully and StatusHandler is never triggered.
I'd like to know the purpose of StatusHandler and what interrupt event will trigger it.
B/R
Re: AXI IIc XIic_SetStatusHandler
Hi @jerry.yau ,
This Status Handler is called Asynchronously from an interrupt context and indicates that the conditions of the IIC bus changed. This handler should not be called for the application unless an error occurs.
Best Regards
Abhinay PS
Give kudos to a post which you think is helpful and reply oriented.
