joe306
AXI Interconnect and AXI Smartconnect
Hello, quick question for the forum members. I'm a little confused when to use the AXI Smartconnect and AXI Interconnect are they the same?
Thank you
Joe
Tags (2)
watari
Hi @joe306
I think that it makes decision on a case-by-case. (port number, transfer size, requirement time and so on.)
But I recommend to use AXI Smartconnect.
Best regards,
watari
Hi @joe306
I'm not sure, but I heard it. The different is performance of AXI transaction.
AXI Smartconnect is higher performance than AXI Interconnect.
But, I don't know the detail.
I hope this helps.
Best regards,
joe306
Hello, thank you for responding to my post. Which one would you recommend?
Respectfully,
Joe
watari
Hi @joe306
Best regards,
joe306
Will do! Thank you very much.
joe306
Hello, on the ZCU106 board the Connection Wizard used AXI Interconnect:
I'm trying to change it to the Smart Connect:
The number of clocks and resets is limited. Why is that?
Thank you,
Joe
