abdulparis
AXI Master Decerr
Hello all,
I am testing a custom AXI Master and I always receive a decerr. For AXI Master, I am using the code available on the link
The hardware design I am using is shown in the figure below. I am trying to initiate read/write transaction. I used Vivado ILA to debug the AXI signals and I noticed that I am always receiving an AXI decerr which is supposed to happen only if there is no slave that supports requested transaction address. I checked my design and this is not the case as it can be seen in the figures below. Besides, everything works fine when I simulate AXI Master with AXI VIP. I am getting the expected behaviour and there is no AXI protocol error.
Normally the custom AXI Master can access the DDR but when I try to access any address in the range, I receive an AXI DECERR. How can I debug the design with more information? Is there something I am doing wrong?
Best regards
kravi
SmartConnect generates 'decerr' in multiple cases, see anything matches with your system:
1. Address decode error (this may not be the case here)
2. non-secure transaction
3. FIXED type burst
Ravi
florentw
Hi @abdulparis,
From the ARM AMBA AXI4 Specification:
"DECERR: Decode error. Generated, typically by an interconnect component, to indicate that there is no slave at the transaction address"
Which address are you trying to access? Are you sure all the transaction is in the DDR range?
Also which SDK version are you using? If 2017.2, please check this AR#69489
Hope that helps,
kravi
3. FIXED type burst
Ravi
abdulparis
Thanks for your replies and help.
I was getting the error because of FIXED type burst.
MAW
