AXI QUAD SPI IN QUAD MODE WITH MICROBLAZE
Spoiler
Hi, all
Iam new to Microblaze and qspi
I need to work on Microblaze with qspi. What i have done is i have created block level design in vivado 2018.3. In our design i have added the microblaze and AXI QUAD SPI in QUAD mode and Slave device is Spansion and after that i added UART.
After creation of the wrapper i exported the our design into xilinx sdk . Now i need to write application code for simple read and write operations.. I tried lot of examples in the xilinx github, i didn't get proper result , i see the transactions in only in these ports  IO0, IO1, SS, SCK ..
But i didn't see any transactions in IO2 and IO3 ports. i think my application code works like spi not qspi.
someone suggested me how can i proceed for it. any reference designs on Microblaze with Axi quad soi in QUAD mode only
Hi @John_24053 ,
Please refer to xapp1280 and download Reference design files to get the flash read and write application for quad mode.
Thanks & Regards
Anil B
Hi, @abommera
Thank you so much for your response
I go through the the xapp1280 reference design, But in this design STARTUPE3 primitive is also used . In my design i didn't use STARTUPE3 primitive only I use Microblaze, AXI Quad Spi in quad mode and uartlite.
And also in reference design they use the micron as a slave memory . In my design i use the spansion (s25fl512s). this entire design developed on virtex ultrascale board.
The problem i am facing is read and write operations.
This is our application code. But i do the simulation i only got io0 and io1 and ss ,sck signals trasactions.
i didn.t see any transactions in io2 and io3.
Please help me how can i change my manage those signals...
thank you
#include <stdio.h>
#include "platform.h"
#include "xil_printf.h"
#include "xparameters.h" /* XPAR parameters */
#include "xspi.h"
#include "sleep.h"
#define SPI_DEVICE_ID XPAR_AXI_QUAD_SPI_0_DEVICE_ID
#define BUFFER_SIZE 17
typedef u8 DataBuffer[BUFFER_SIZE];
int SpiPolledExample(XSpi *SpiInstancePtr, u16 SpiDeviceId);
static XSpi SpiInstance; /* The instance of the SPI device */
u8 ReadBuffer[BUFFER_SIZE];
u8 WriteBuffer[BUFFER_SIZE];
int main(void)
init_platform();
int Status;
Status = SpiPolledExample(&SpiInstance, SPI_DEVICE_ID);
if (Status != XST_SUCCESS) {
return XST_FAILURE;
//return XST_SUCCESS;
cleanup_platform();
return 0;
init_platform();
//ps7_post_config() ;
int Status;
u32 Count;
XSpi_Config *ConfigPtr; /* Pointer to Configuration data */
ConfigPtr = XSpi_LookupConfig(SpiDeviceId);
if (ConfigPtr == NULL) {
return XST_DEVICE_NOT_FOUND;
Status = XSpi_CfgInitialize(SpiInstancePtr, ConfigPtr,
ConfigPtr->BaseAddress);
return XST_FAILURE;
Status = XSpi_SetOptions(SpiInstancePtr, XSP_MASTER_OPTION | XSP_MANUAL_SSELECT_OPTION);
return XST_FAILURE;
XSpi_Start(SpiInstancePtr);
XSpi_IntrGlobalDisable(SpiInstancePtr);
xil_printf("%d",XSpi_GetStatusReg(SpiInstancePtr));
u8 WriteBuffer[BUFFER_SIZE]={0xB,0x3,0x1,0x0,0x0,0x1,0xC,0x5,0xA,0x1,0x0,0xA,0xC,0xC,0x3,0xE,0x0};
u8 ReadBuffer[BUFFER_SIZE]={0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0};
XSpi_SetSlaveSelect(SpiInstancePtr, 0x01);
while(1)
XSpi_Transfer(SpiInstancePtr, WriteBuffer, NULL, BUFFER_SIZE);
for (Count = 0; Count < BUFFER_SIZE; Count++) {
xil_printf("\n read %d",ReadBuffer[Count]);
xil_printf("\n write %d",WriteBuffer[Count]);
if (WriteBuffer[Count] != ReadBuffer[Count]) {
print("fail");
return XST_FAILURE;
print("\n success");
return XST_SUCCESS;
HI,
I attached the simulation results that i have got.
Only problem with io2 and io3 signals i didn't see any transactions on those signals..
please anyone suggested me what if iam doing wrong,
I am wonder about this.
Thank you
