Jonas_C
AXI Quad SPI
I tried to use Arty S7 EVB to send SPI signal, and use "Saleae logic Analyzer Tool" to get the data, but the data retrieved is not the data I want to send in the program.
Can someone help me see what I am doing wrong?
Thank for your time,
#include <stdio.h>
#include "platform.h"
#include "xil_printf.h"
#include "xintc.h"
#include "xspi.h"
#define BUFFER_SIZE     8
static XIntc Intc;
static XSpi Spi;
volatile static int TransferInProgress;
int Error;
u8 WriteBuffer[BUFFER_SIZE]={0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
u8 ReadBuffer[BUFFER_SIZE]={0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
void SpiHandler(void *CallBackRef, u32 StatusEvent, unsigned int ByteCount)
    TransferInProgress = FALSE;
    if (StatusEvent != XST_SPI_TRANSFER_DONE) {
        Error++;
int main()
    int Status;
    XSpi_Config *ConfigPtr;
    init_platform();
    ConfigPtr = XSpi_LookupConfig(XPAR_SPI_0_DEVICE_ID);
    if (ConfigPtr == NULL) return XST_DEVICE_NOT_FOUND;
    Status = XSpi_CfgInitialize(&Spi, ConfigPtr, ConfigPtr->BaseAddress);
    if (Status != XST_SUCCESS) return XST_FAILURE;
    Status = XSpi_SelfTest(&Spi);
    Status = XIntc_Initialize(&Intc, XPAR_INTC_0_DEVICE_ID);
    if(Status != XST_SUCCESS) return XST_FAILURE;
    Status = XIntc_Connect(&Intc, XPAR_INTC_0_SPI_0_VEC_ID,
                (XInterruptHandler)XSpi_InterruptHandler,
                (void *)&Spi);
    Status = XIntc_Start(&Intc, XIN_REAL_MODE);
    XIntc_Enable(&Intc, XPAR_INTC_0_SPI_0_VEC_ID);
    Xil_ExceptionInit();
    Xil_ExceptionRegisterHandler(XIL_EXCEPTION_ID_INT,
                (Xil_ExceptionHandler)XIntc_InterruptHandler,
                &Intc);
    Xil_ExceptionEnable();
    XSpi_SetStatusHandler(&Spi, &Spi, (XSpi_StatusHandler)SpiHandler);
    Status = XSpi_SetOptions(&Spi, XSP_MASTER_OPTION |
                                   XSP_MANUAL_SSELECT_OPTION);
    Status = XSpi_SetSlaveSelect(&Spi, 1);
    XSpi_Start(&Spi);
	while(1){
		for(int i=0; i<BUFFER_SIZE; i++){
			WriteBuffer[i] = i+0xA0;
			ReadBuffer[i] = 0;
		for(int i=0; i<8; i++){
			TransferInProgress = TRUE;
			XSpi_Transfer(&Spi, WriteBuffer, ReadBuffer, BUFFER_SIZE);
			while (TransferInProgress);
		xil_printf("SPI Transfer Finished! (Error Count= %d \n\r", Error);
		cleanup_platform();
    return 0;
clk use 100MHzclk use 100MHz
IP ConfigurationIP Configuration
Analyzer tool read dataAnalyzer tool read data
venui
Hi ,
Can you probe the same signals from CRO and re-confirm.
Venu
venui
Hi ,
Venu
Jonas_C
Hi Venu
Thank you for your suggestion.
The CRO measured the signal to be correct. It seems to be a problem with my PC Tool.
dimpy
Hello @Jonas_C
Can you please tell me the procedure you followed?
I am doing the same but i am not getting any signal on the oscilloscope.
Kindly help me.
Jonas_C
Hi dimpy
At that time, I just watched YOUTUBE to learn.
Attached is a video of learning at that time.
Hope it helps you.
https://youtube.com/playlist?list=PLj4QI1KaYRNbffMxNHRet8KVNTyfyDvPN
