AXI Stream Switch Behavior
I have a weird trouble with the AXI stream switch.
I have three AXI-stream FIFOs that feed a switch in a 3:1 configuration. The output then goes to an MCDMA.
Slot 0: Switch output
Slots 1-3: Switch inputs.
I see the data from the first FIFO transmit correctly, and then the second, but all the while the third FIFO is getting this every-other cycle TREADY that messes up the FIFO output. It never actually gets transmitted through the switch.
I believe I found a solution.
Each stream has a TDEST fixed: 00, 01 and 10
I had set the switch to use values 0x00000000 for TDEST low and 0x00001111 for TDEST high.
Changing to 0x0000FFFF for TDEST high has resulted in expected functionality.
