Hi all,
I'm trying to put together some design requirements for a system that samples 32 ADCs to gather 24MB of total data per second.
This data is required for transmission over a USB 2.0 interface and I've identified the AXI USB 2.0 Device as a potential solution.
If anyone has experience using this core, or just know your way around a user guide, could you please help me with the following:
- Does this sound like something that could be implemented onto a mid-range Artix-7? (Cost is an important factor in this design)
- Does 24MBps of payload data sound realistic for this core/device pairing?
- What design advice do you have to help ensure this data rate could be reached, e.g. efficient use of the endpoints, using DMA etc.
Many thanks!
