AXI Vivado IP to write AXI location fpga internaly generated data and address
Hello. Is there in vivado an Axi Master IP that I can connect to axi smartconnect slave input to write to an axi location using data and address internaly generated by the fpga? Thank you.
I solved my problem writing my own custom axi IP. However if it would exist an IP that can do this let me know. Thank you.
