matic
AXI burst access to the AXI full slave from Microblaze - is this possible?
Hi.
I have successfully implemented a custom packaged IP as a AXI (full) slave. I wanted to do burst read/write access to it from a Microblaze using memcpy() function like this:
memcpy(received_data, (Xuint8 *)XPAR_FTDI_RX_TX_0_S00_AXI_BASEADDR, 512);
This read operation works, but as it looks from the ILA (snapshot attached below) this is not a true burst access. My question is, if this is even doable from the Microblaze C code? If it is, what am I doing wrong?
PS: That 0x12345678 data on the S_AXI_RDATA port is there assigned for the time when the read access is not going on.
Thank you.
necare81
Voyager
Voyager
In general no processor, be it Microblaze or x86 or ARM, can turn user C code into an arbitrary burst because no assembly instructions implement a burst.  If your processor architecture is wider than your bus you will get a burst but that is a rather silly setup to have in general.
You can do some things to get a cache hierarchy to do a burst of one cache-line sized burst or you can use a separate DMA hardware block.
With a Microblaze you might be able to create a custom instruction to create a burst but I've never tried to any custom instructions.
necare81
Voyager
Voyager
