AXI master access to microblaze LMB memory
I'd like to know if there is something wrong in having BRAM memories being accessed by both LMB and AXI controlers?
I've build this system (see fig. below) in a Zynq device. My goal is to have one microblaze exchanging data with a VDMA (via "lmb_bram_0") and with the PS (via "lmb_bram_1").
I've linked my program into "lmb_bram_0" which is connected to the microblaze Intruction and Data LMB.
Then I write some data into "lmb_bram_1" with the PS but the microblaze is not seen it.
Moreover, I've realized that "lmb_bram_1" contains not null data before the PS write anything (contrary to what I expected). This data seems to be my program, i.e. the same contents of lmb_bram_0.
Please, any idea of what is happening.
Regards.
Yaset
There is no reason why this shouldn't work.
Things to look at:
- MicroBlaze linker script
- The mask and base address property on the LMB BRAM Controllers
Göran
Things to look at:
Göran
Hi Göran,
I've check out the LMB Bram controler' mask address property and it was set to "Manual" (I don't remember me doing that).
So I set it to "Auto" and now my system works.
Thank you a lot,
Yaset
