beandigital
AXI traffic generator andchecker
Do Xilinx provide IP that would generate AXI write and read requests and then compare the read data to the write?
hbucher
@beandigital PG125
https://www.xilinx.com/support/documentation/ip_documentation/axi_traffic_gen/v2_0/pg125-axi-traffic-gen.pdf
Check page 67
hbucher
@beandigital PG125
Check page 67
puja
Dear Sir,
I am simulating AXI Traffic Generator in Master Loopback mode without PS intervention. I have connected M_AXIS_MASTER to S_AXIS_MASTER. I have given the appropriate signal to clk and reset port. I have generated a high pulse at core_ext_stop and core_ext_start port. When I simulate the design, axis_err_count port is 0000.
To check whether axis_err_count port is counting no. of errors properly, I corrupted the m_axis_1_tdata as follows and, then fed to s_axis_1_tdata:
assign s_axis_1_tdata_c = m_axis_1_tdata + 32'd10;
Still s_axis_err_count is 0000. Please suggest how to resolve this issue.
Further, I brought up all AXI stream data interface signal to the top Verilog module as port, then I simulated the design. I observed following in the simulation result:
1. m_axis_1_tvalid and s_axis_1_tready is never high. Please see below the attachment.
Please help me out to sort the above issue.
Any help would be appreciated.
Thank you and Regards,
Puja Kumari
