mcarniel
Access to debug registers of R5_0 core of XAZU3EG through JTAG interface
Hello all,
I am a software developer working for a company which builds their own universal in-system programmers.
I need to write a driver for our programmer in order to program the fuses of an XAZU3EG device, using JTAG protocol to communicate.
I have enabled the ARM DAP and I need to initialize it in low power domain in order to operate correctly.
After having done that, I write to two registers through AHB bus:
- 0xFF9A0000 (RPU_GLBL_CNTL) -> value 0x8 in order to put RPU cores in split mode;
- 0xFF5E023C (RST_LPD_TOP) -> value 0x188FD6 in order to exit core r5_0 from reset.
After this I need debug access to R5-0 core in order to halt cpu, write binary code in OCM memory and make it execute.
Once I tried to access R5_0 debug registers (base address 0x803F0000), I obtained STICKY error.
Can you please tell me which is the complete sequence that I should follow in order to do what is needed?
Thank you in advance.
