Adjust I2C clock on iic0 interface
I'm new in programmaing zynq and vivado and have a problem using i2c interface.
I use a example project in vivado including several interfaces, uart, i2c....
When I export the design to SDK and add the new application project Template Peripheral Test,
the serial iic clock is about 3 MHz.
The IicPsSelfTestExample(u16 DeviceId) returns sucessfull.
I use the function
XIicPs_MasterSendPolled()
for sending iic data.
Wher can I do the configuration for the iic interface (adjust the clock)?
I can't find the paramerters anwhere.
Thank you
geimel
The I2C clock speed can be controlled by modifying the divisor_a and divisor_b values and these can be altered by writing into the I2C control register.
For more details please refer to the I2C controller and register details in the TRM.
http://www.xilinx.com/support/documentation/user_guides/ug585-Zynq-7000-TRM.pdf
Hope this helps.
Achutha
Geimel,
Was the information in my last post help you understand the clock configuration?
Achutha
