sarissabenz
Application code can not read XADC fast enough!
Hello everyone!
I got my XADC working, so that I am able to read my external voltages.
Now I wrote an application code to read these two voltages, via file.open(...) -> file >> array -> file.close()
The problem is, that I want to read the voltages with 320kSamples per second.
But these three commands take to fast time. The fastest time in my eyes is, to read the raw-values directly from the register.
But I am so far a newbie, and feeling a bit lost, how to do this! And the internet also don't have examples.
Is there a way/is someone having examples, to read these registers?
Hope someone could help me!
thanks!
@klumsde
drjohnsmith
To I under stand your reading a single value from the adc, via a processor,
which chip , tools an languages / strategies you using ?
where do you think the time is being taken ?
sarissabenz
Sorry forgot these informations:
I use the Zybo Z7-20 Board from Digilent.
I have PetaLinux running on the PL.
I want to read two channels
My program code is in C++.
The time is taken from the commands:
file.read("path");
file >> array_to_save_the_voltage;
file.(close);
---> I need here arround 65 to 70 usec
drjohnsmith
You asking about how fast can you do something,
The question you need to know the answer for is   how long does each of the line ls of code take ?
Once you have some numbers you can delve into the solution
sarissabenz
I know, that the way of my solution is to slow.
So I am looking for a faster way.
The faster way is to read the voltages directly from the registers. Work directly from the registers.
But I find no where examples or solutions.
How would you solve this problem, is there another way to solve it?
drjohnsmith
You ask how I would solve this problem
Like all problems, understand and quantify the problem is always the first step.
In your case, as a new to this,
you need to find out how long each of the different parts of your current solution take,
Do you know how to get that timing information ?
sarissabenz
The times are:
for read, write and close: 70uSec
multiplied for 2 channels: 140uSec.
And I know that to open a file (/sys/bus/iio/devices/iio\:device1/....) and to read is taking VERY long
drjohnsmith
Can I ask, are you after learning how, or heres the answer ?
sarissabenz
Is there a way to read the XADC like a GPIO button, with the function?
inline unsigned int gpio_read(void *gpio_base, unsigned int offset){
  return *((volatile unsigned *)(gpio_base + offset));
And if yes, where can I find the gpio_base (in the case of the XADC, the XADC_base?) and the offset?
sarissabenz
Hello again!
I wrote now some application code for the linux. to read directly the external voltages from the registers.
As an attachment you can see my code.
The offsets for VAUX6 and VAUX14 (0x16 and 0x1E) i rote in the XADC data sheet. But when I try to map from /dev/iio:device1, i get the message, that I am not able to map. And if I want to map from /dev/mem (with the same offsets) I get wrong values.
Can someone help me, why I can not map from /dev/iio:device1. Or that are the right offsets for /dev/mem/
Thanks a lot for your help ;-)
@klumsde
sarissabenz
sorry, forgot the attachment
or here is the code:
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <fcntl.h>
#include <time.h>
#include <errno.h>
#include <string.h>
#include <iostream>
#include <fstream>
#include <cstring>
#include <ctime>
#include <netinet/in.h>
#include <arpa/inet.h>
#include <sys/types.h>
#include <sys/time.h>
#include <sys/mman.h>
#include <sys/socket.h>
#define MAP_SIZE    0x10000
#define XADC_CHANNEL_US    0x16    //VAUX6
#define XADC_CHANNEL_IR    0x1E    //VAUX14
unsigned int read_data(void *base, unsigned int offset){
    return *((volatile unsigned *)(base + offset));
int main(int arg, char *argv[]){
    int fd_xadc;
    char *xadc_val = "/dev/iio:device1";
    //char *xadc_val = "/dev/mem";
    void *xadc_val_ptr;
    int i;
    unsigned int VolUS[i], VolIR[i];
    //char BuffVolUS[i], BuffVolIR[i];
    //++++++++++MAPPING++++++++++//
    fd_xadc = open(xadc_val, O_RDWR|O_SYNC);
    if (fd_xadc < 1){
        printf("Invalid XADC device file of Segment: %s\n", xadc_val);
        return -1;
    xadc_val_ptr = mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_SHARED, fd_xadc, 0);
    if (xadc_val_ptr == MAP_FAILED){
        printf("Mmap of XADC failed\n");
        return -1;
    //++++++++++READ++++++++++//
    for(i=0;i<100;i++){
        VolUS[i] = read_data(xadc_val_ptr, XADC_CHANNEL_US);
        VolIR[i] = read_data(xadc_val_ptr, XADC_CHANNEL_IR);
        //sprintf(BuffVolUS[i], "%d", VolUS[i]);
        //sprintf(BuffVolIR[i], "%d", VolIR[i]);
        printf("%i --- %i\n", VolUS[i], VolIR[i]);
    return 0;
sarissabenz
Found my mistake! I didn't add the baseaddress to the mmap command.
But now I can not see any voltages print.
I read something about disable the driver.
so I added to system-user.dtsi a   status = "disabled";
If i boot now my petalinux, in /dev/ there is the xadc not appearing.
But the voltages I print are still: 0
Does someone know why?
