Apply Zynq processor preset from TCL
In my project I have several processor preset files (TCL-files) that I apply to the Zynq processor depending on the target I am building for. I use the Vivado Re-customize IP GUI to apply the preset files to the Zynq processor in my design.
This works fine, but I would like to do the same using the Vivado TCL command line interface. Is this possible? It doesn't look like I can simply "source" the preset file.
/Andre
Re: Apply Zynq processor preset from TCL
I found a solution:
source processor_config.tcl
set presets [apply_preset 0] foreach {k v} $presets { if {![info exists preset_list]} { set preset_list [dict create $k $v] } else { dict set preset_list $k $v } } set_property -dict $preset_list [get_bd_cells zynq_ultra_ps_e_0]
you Might need to parse the file slightly, but you should be able to source this from tcl console.
Ok, let me rephrase my question: How specifically can you do this with TCL?
The processor configuration TCL file is created using the Vivado PS configuration GUI, under Presets->Save Configuration...
This TCL file gives me 3 functions:
- proc getPresetInfo
- proc validate_preset
- proc apply_preset
The apply_preset function returns the processor configuration, but I want to know how I can apply this configuration. I have tried to create a simple TCL-script that uses this function, but no luck so far:
  if {![info exists value]} {
    set value [list $k $v]
  } else {
    lappend value [list $k $v]
startgroup
set_property -dict $value [get_bd_cells zynq_ultra_ps_e_0]
endgroup
Any suggestions?
I found a solution:
