Asynchronous external data abort on baremetal application
I created a piece of code used to verify if I can erase/write/read the FLASH on the Qspi interface.
I based my code on the FSBL code, and added the functions to erase and write.
My piece of code was working good on a custom SBC, I then had to run it on the target board (from which my testboard was derived).
The weird thing is that on that board, I get an asynchronous external data abort (with ARM DFSR at 0x1406 and DFAR at 0).
It is very strange, because this abort happens in the Qspi driver, in the XQspiPs_PolledTransfer function, when the code copies the data read from Qspi in user buffer.
Anybody has an idea of what is happening.
François
Community Manager
Community Manager
Re: Asynchronous external data abort on baremetal application
What frequency are you operating at? What is the flash that you are targeting? Is it listed under AR#50991?
Can you please share QSPI schematic here?
Does this flash pass selftest driver code?
SOLVED : Asynchronous external data abort on baremetal application
So I finally found the error.
Did not take time to verify if this is outlined in the manual.
It turns out that the difference between the boards that made this problem appear is the size of the FLASH. The working one was a 256MBits, and the one that raised the error was 32MBits.
So that problem appears because the initialisation code of QSPI (the one from FSBL) set the QSPI to linear mode when the size of the flash permits this. Once the controller is set to linear mode, it is no more possible to explicitely send commands to the FLASH (read status flag for exemple).
If I let the QSPI in IO mode, my test code is working great.
Re: SOLVED : Asynchronous external data abort on baremetal application
Hello!Do you know how to set the QSPI to IO mode? In your code,I made the following changes:
if (QspiFlashSize <= FLASH_SIZE_16MB) {
LinearBootDeviceFlag = 1;
XQspiPs_SetOptions(QspiInstancePtr, XQSPIPS_MANUAL_START_OPTION |
XQSPIPS_HOLD_B_DRIVE_OPTION);
XQspiPs_SetLqspiConfigReg(QspiInstancePtr, SINGLE_QSPI_IO_CONFIG_QUAD_READ);
XQspiPs_Enable(QspiInstancePtr);}
However, I can only read data from the QSPI, when I want to write data to the QSPI, it can not work.
Thank you!
