parithyila
Axi interconnect
I wrote master Axi code and created and package new ip when i connect with axi interconnect , it is failing in validation ip . it is throwing an ID WIDTH error .
is there any solution
dpaul24
@parithyila,
hi some time it is validate passing
It must pass validation EVERYTIME, else you have a design problem!
I don't have details of your design, so I can only answer vaguely.
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
dpaul24
@parithyila,
I would connect it first to an AXI BFM and verify before connecting it to the axi interconnect of the design.
parithyila
hi
when i connect AXI slave bfm validation passes
dpaul24
@parithyila,
In that case are you sure there were no errors during IP packaging?
parithyila
Hi it is not showing any error during IP packaging i also observed that when i use two master output from interconnect than it is not throwing validation error
parithyila
dpaul24
@parithyila,
