ivkome
[BD 5-336]
Hello Support Team,
i'm facing to the following problem. I tried to design some IP Blocks on Vivado 2020.1 version, but could't compile it successfully because of the following message from tcl:
ERROR: [BD 5-336] This command cannot be run, as the BD-design is locked. Locked reason(s):
* Block design contains locked IPs. Please run report_ip_status for more details and recommendations on how to fix this issue.
List of locked IPs:
design_1_CORTEXM3_AXI_0_0
ERROR: [Common 17-39] 'validate_bd_design' failed due to earlier errors.
Could you please help me to solve the issue or what do you recommend me to do?
Tags (2)
stephenm
Do you have the CortexM3 in your IPI design? You would need this.
You can get this from ARM:
https://www.arm.com/en/resources/designstart/designstart-fpga
I have tested this before (M1 and M3) using the debug bridge:
stephenm
You need to Tools -> Report -> Report IP Status, and update all your IP
ivkome
Hi Stephenm,
thanks for the suggested solution. However it didn't work, because i was unable to choose the Cortex M3 to be updated listed in Report Statut. (See Screenshot below)
i think, the Cortex M3 isn't existing the IPs folder.
Further more, i'm confuse between the instructions given in the YouTube Link , about how to download the ARM M3 for the FPGA and how possible i can update the IPs through Vivado, if it's possible. So, please how can i get this solved (ARM Core M3 in my FPGA) ? Thanks in advance for the suggestions.
2021-04-22_10h03_29.png)
stephenm
ivkome
Yes, after downloading the the Zip-Folder of the ARM M3 from the arm website and follow the instruction from the YouTube link below, i could find out the CortexM3 in the IP-Catalog. It's funny, but i needed to restart Vivado may be 3 times and realize after, that it's available.
Thanks for the suggested solutions.
stephenm
You can just refresh the IP repo
