piyushmanavar
BID and AWID are not matched in AXI interface
I am developing a project in which we are using AXI protocole as a part of the syatem.
We stuck at a probleam where we axpecting BVALID signal from slave but it is not comping from the slave ip.  We are not able to find the actual cause of the probleam.
We are using IP DMA/bridge subsystem for PCI express in our prohect as a part of the saytem and testing this system with testbench (msater in this case).
Also found that BID (from slave) should be matched with AWID form testbench (master) but which is not matching.
Please reply
Piyush Manavar
dgisselq
@piyushmanavar,
On the face, this bug looks like the same issue as this one.  It's not limited to just the BID response, RID has the same bug.
Can you check if this is the same bug?  If not, then please post your code and we'll then have something a bit more tangible to discuss and find the fault with.
Thanks!
Dan
