BMM back-annotated generation in Vivado
I have a xxx.bmm file defining address map with BRAM instances name I want to fill.
In ISE, I provide this file and set the -bm switch to NGDBuild which generates the back-annotated xxx_bd.bmm file with the BRAM
placement information. Then I can simply use data2mem.
What is the equivalent in Vivado ? I found some documentation only related to project having a block design or processor IP.
I add the BMM file in the project but I can't set the BMM_INFO_DESIGN property because I have no block design...
Any advice ? Thanks.
Antonin
Hi @broquet,
Please check the Work-around-2 in the AR#63041  https://www.xilinx.com/support/answers/63041.html
the work around-1 will discuss in case of the Block design and work-around-2 discuss out side of BD.
Hope this will helps you.
Best Regards,
Srikanth
Hi @savula,
Thanks for your reply.
I saw this AR#63041. The problem I see with the Work-around-2 is that I need to fill the BRAM placement each time I run implementation ? The BRAM placement is not fixed. And I don't want to constraint it.
That's why I asked a flow like in ISE. If I give only BRAM instances, which don't change from a design to another one while I don't change net name of course. Then ISE (NGDBuild) is able to associate BRAM placement information to instance.
Here with the Work-around-2 in Vivado, I have to manually set it at each implementation. Right ? Tell me if I'm wrong.
Antonin
Hi @stephenm,
Thank you for your TCL script ! It is exactlly what I needed. I changed it a bit for my needs, and it works.
Antonin
