07-28-2017 07:19 AM
I have ZCU102, rev 1.0. I have created simple design when I try to turn on LED somewhat according to this tutorial: https://www.youtube.com/watch?v=8i8GLF-Md3U
Problem is, when I generate a bitstream and I try to program FPGA in SDK, I get "Bitstream is not compatible with the target revision, use -no-revision-check to allow programming."
Is there an explanation as to why is this happening? I have correctly chosen ZCU102 as target board in Vivado 2017.2.
Also, what does it mean to use -no-revision-check to allow programming? How do I do it? I have Windows, just a note.
Thank you.
07-28-2017 08:55 AM
When you program the device under Vivado, if you receive an error message similar to this one:
"[Labtools 27-3303] Incorrect bitstream assigned to device. Bitstream was generated for part xcvu095-ffva2104-2-e, target device (with IDCODE revision 1) is compatible with es2 revision bitstreams.
To allow the bitstream to be programmed to the device, use "set_param xicom.use_bitstream_version_check false" tcl command."
Copy and paste the "set_param" command up to and including the "false" to your tcl command line on Vivado.
Hope this helps
07-28-2017 07:34 AM
There are several revisions for the device of ZCU102, like es1 and es2.
You can add them at install time (add engineering samples).
Anyway the message is not critical and when you receive the message you also receive the tcl command that you have to use to ignore this. Copy and paste it in the tcl command line (tcl tab).
07-28-2017 07:56 AM
Thank you for your answer, tcl tab is to be found in SDK as XSCT?
Because if yes, then this command is unknown. It even seems to be more of a flag to some other command.
07-28-2017 08:17 AM
Tcl tab is on Vivado tool
07-28-2017 08:36 AM
07-28-2017 08:52 AM
I have found a workaround. I alternatively programmed FPGA using Hardware Manager. Problem with revision can be very simply and intuitively solved there.
07-28-2017 08:55 AM
Hope this helps
12-13-2017 03:19 PM - edited 12-13-2017 03:20 PM
Has anyone found an SDK solution to this problem. I understand the solution for Vivado and yes that works. Unfortunately that is not helpful when running the SDK. When you run the SDK debugger it first attempts to download the file and produces the error message but I have not been able to determine where I need to go in the SDK to specify -no-revision-check so that the SDK programmer does not fail.
12-14-2017 04:52 AM - edited 12-14-2017 04:53 AM
I was able to workaround this in sdk by doing the following:
from pull downs xilinx->xsct console
xsct% targets
1* PS TAP
2 PMU
3 PL
4 MicroBlaze Debug Module at USER2
5 MicroBlaze #0 (Running)
6 PSU
7 RPU (Reset)
8 Cortex-R5 #0 (RPU Reset)
9 Cortex-R5 #1 (RPU Reset)
10 APU (L2 Cache Reset)
11 Cortex-A53 #0 (APU Reset)
12 Cortex-A53 #1 (APU Reset)
13 Cortex-A53 #2 (APU Reset)
14 Cortex-A53 #3 (APU Reset)
xsct% targets 5
xsct% fpga -f download.bit
bitstream is not compatible with the target revision, use -no-revision-check to allow programming
xsct% fpga -f download.bit -no-revision-check
initializing
0% 0MB 0.0MB/s ??:?? ETA
4% 1MB 2.2MB/s ??:?? ETA
7% 1MB 1.9MB/s ??:?? ETA
xsct% dow ../project_1/project_1.sdk/hw/Debug/hw.elf
at this point you can debug the software by going into "debug configurations" and in the "target setup" tab set the "debug type" to "attach to running target"
note: this was all done in 2017.3.
03-15-2018 05:45 AM - edited 03-15-2018 05:51 AM
I had the same issue with the ZCU102 Rev 1.0 Evaluation Board,
in the SDK you have to type in the xsct% fpga -file <path to bit-file> -no-revision-check.
Importan for Windows is the path, it is normaly like: Examplepath\Examplefile
you have to exchange the "\" by "/" that it works. I hope it helps.
Best regards,
Franz
note: tested with SDK 2017.4
05-07-2018 01:25 PM - edited 05-07-2018 01:27 PM
Franz,
Thank you for posting the only intelligent answer.
I could not figure out how to turn off BIT file checking in the Xilinx SDK and your solution worked perfectly with Xilnx SDK 2018.1.
Now I need to figure out how to give you 100 kudos...
Michael
11-29-2018 04:07 AM
These solutions are great workarounds, but they do not solve the problem.
I've been able to load the FPGA via vivado or the SDK with the solutions posted above, but I still get the 'bitstream incompatible' error when I try to load with petalinux-boot.
Any solution or workaround for that?
