Block Diagram
This is my reference circuit. Can u please explain what is happening in this in a sequential manner?
Hello @C9
If you can organize your points and post them, you'll get some useful information from the forum members.
If you don't mind, please close this thread, kudo and accept as solution.
Thank you
Hello @C9
What is your question or purpose of this reference circuit? I think, your colleagues can explain it to you.
Thank you
Voyager
Voyager
"This is my reference circuit." and you don't know what it does ??????????????
== If this was helpful, please feel free to give Kudos, and close if it answers your question ==
Advisor
Advisor
@C9 From what you've posted, the MicroBlaze processor will do something involving ethernet and a UART. That's ... about all anyone can say with the information you've provided.
It's sort of like someone taking a photo of a car and saying "hey, can someone tell me where this car will drive over the next two weeks?". Obviously the driver could (just like the person who designed this circuit can probably tell you what it does) - but nobody else can help.
Hello @C9
Thank you
Hello @C9
This is just my opinion.
MicroBlaze reads the program from the Local Mempry and executes it.
MB's M_AXI_* ports are connected to several peripherals ( AXI Ethernet Lite, AXI UART Lite, BRAM Controller, and AXI Interrupt Controller ) via AXI Interconnect.
MB reads/writes registers of these peripherals and processes Ethernet communication, UART communication, and interrupts. As for BRAM, it will be able to Read/Write as memory.
You'll be able to try them out with an evaluation board and an Example Design. Please give it a try!
Thank you
